Old 05-08-2011, 05:28 PM
Souplaman's Avatar
Souplaman Souplaman is offline
1/24 Camel Trophy 1989 - Amazon
Hello my friends,
I'm starting my new project, which will be a diorama of Amazon crossing, in Camel Trophy.
The kit i'm going to use is the well known Italeri kit:
In which i'm going to make a lot of changes in order to make it like the competing one.
Old 05-08-2011, 05:29 PM
Souplaman's Avatar
Re: 1/24 Camel Trophy 1989 - Amazon
The Italeri kit, is totally unsuitable for Camel Trophy, and so it had to be chopped off in many places. The interior will be reconstructed since it has not rear seats, and in the body, i had to rescribe the panel lines, and make the back doors. Also the grills were cut out since they were out of scale...
Maybe i should leave the drivers door open...i'll see...
The new back doors were needed hinges, so i replicate them with the help of epoxy putty and hot plastic.
The rear door was also cut since i want to display the interior work and also it didnt fit right.
The roof will be totally changed since it needs a hell of work in order to be correct
That's all for now, thank you for your time
Old 05-08-2011, 06:59 PM
ChillyB ChillyB is offline
A very cool and very exciting project. I'll be following along. This is something I'd like to build someday, but for now I'll have to settle for watching your build.
Old 05-09-2011, 12:50 PM
sam01contact's Avatar
sam01contact sam01contact is offline
I like this project! What decals are you using?
Old 05-09-2011, 04:15 PM
Souplaman's Avatar
Thank you guys for your kind words!
sam01contact: i'll use the ones from esci and if i dont find them i'll make my own
Old 05-10-2011, 04:26 PM
Souplaman's Avatar
A small update since we go deeper to this project!
I made a new base for the chassis, since the original was very soft and it wouldnt tolerate the conversions. I used thick plastic glued with epoxy glue. This is only the basis and is not in its final stage:
Check if everything is aligned:
Then i made new bases for the rear seats:
and i have opened the drivers' door:
Lastly, i slowly started to cut out parts of the roof, since it needs a lot of major changes:
That's all for today folks, hope you like it!
Old 05-10-2011, 05:36 PM
Go-figureit's Avatar
Go-figureit Go-figureit is offline
It's looking good so far - I love these sort of projects - something different and exciting - will be watching with interest, best of luck with it,
Cheers,
Paul
"Never let accuracy prevent the making of a good image - strive for the Happy Medium - more than too little and less than too much"!
Old 09-27-2011, 10:32 AM
gtziaf's Avatar
gtziaf gtziaf is offline
Great start to a unique project.
Good luck until the end...
YAMAHA YZR-M1 2006 CAMEL No.46 YongGun Park Completed Projects / Gallery 31 10-07-2012 02:32 AM
Land Rover 109" LWB Camel Trophy Iskandana Completed Projects / Gallery 4 08-08-2010 04:18 AM
1989 caprice classic jsb8097 Caprice 3 02-26-2010 08:54 AM
code 24 zetan Corolla/Matrix/Voltz 2 04-10-2009 09:59 AM
1989 Grand Marquis has no power a19thcfx Grand Marquis 2 03-29-2009 04:52 PM
