Old 05-28-2003, 03:45 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
ZC questions
I recently bought a 90 civic SI that has a real nice body (no rust, no dents) along with a nice interior. The guy i got it from didn't know much about cars, so I got it for $700. I had to replace the clutch, and while I was screwing around under the hood, I noticed " 92 ZC " faded, but written on the valve cover. This leads me to believe that it obviously isn't the original engine, and that it could be a SOHC ZC. Does anyone know of a way to see if it really is a ZC? If it is, would it be possible to switch the head to the DOHC version while using the same block, and most of the other existing parts?
Old 05-28-2003, 08:51 PM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
right where the block meets the tranny at the bottom left of the motor, there is an engine stamp and it will say ZC on it if it is a ZC, um the DOHC head will not fit on the SOHC motor, too different motors.
*TeamchokE* i love to support my boys, www.HBultimatetraining.com ,
www.chrisbrennan.com ,
www.zentraediracing.com . all my boys.
Old 05-28-2003, 09:18 PM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
its kinda obvious if you have seen a SOHC and DOHC motor. I dont want to make it seem like an insult but its generally easy to tell. SOHC has a single cam so its a circle on the right of the block and the DOHC has two so i think it has a flat portion between the two cams.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 05-28-2003, 10:14 PM
I know what the difference between the two heads is, I have seen the two different heads before, it's just that I have never seen the blocks without the heads to know if they were different.
Old 05-29-2003, 07:07 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
SOHC block will not work with a DOHC Head or vice versa because they have different setups. And if it's a zc, it will say ZC not 92 ZC on the block.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 05-29-2003, 09:24 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
It sounds like "92 ZC" was written somewhere on the valve cover...like in junkyard pen or something...
I think I have a shot of my engine code...like the other dude said..you'll see this under the distributer, just above the tranny towards the front of the motor..mine is sitting on an engine stand, but it is right next to where the tranny connects.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 05-29-2003, 09:46 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
heres the code on my sohc
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-29-2003, 10:06 AM
sastanley's Avatar
AF Premium User
Thumbs up
cool melt...that is a better pic to show where it will be in the car - thanks yo
-Shawn
'91 Civic DX sedan
Old 05-29-2003, 11:16 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Can you please add the small image code around your sig, or shorten it.
Old 05-29-2003, 11:19 AM
sastanley's Avatar
AF Premium User
Yo bambam...all you have to do is add [ size=1 ] - without the spaces, just before the text in your sig and then [ /size ] at the end to close it...do the same with the color tag you put in there and it should work too
-Shawn
'91 Civic DX sedan
