Go Back   Automotive Forums Car Chat > Volvo > S40
Old 05-05-2011, 04:41 PM
Hognewbie Hognewbie is offline
Electric Fan
the electric fan on my 2003 runs constantly. Whether I just start the car or its been running awhile. Whether its hot or cold. Any ideas?
Old 05-05-2011, 07:12 PM
danielsatur danielsatur is offline
Re: Electric Fan
A bad coolant Temp sensor will enable both fans to stay on.
Old 05-12-2011, 09:10 AM
Re: Electric Fan
I replaced the blower resistor because my a/c panel and fans were acting crazy. The a/c would turn on & off when it pleased, there would be heat blowing out of the vents without anything turned on and it was 100 degrees plus outside and the re-circ would turn on & and off buy itself. The black a/c fan would turn on and off randomly with or without the a/c and the white cooling fan never came on.
When I first installed the resistor I tested it. With the a/c turned off the black cooling fan turned on as soon as the engine was started and the white a/c fan turned on and off with the a/c. It seems to have fixed the probs with the a/c button and no more heat blowing, however the recirc still turns off after I turn it on. Today when I drove it the black fan won't turn on and the white fan turned on and off a few times w/o the air.
Anybody have and ideas other than the resistor?
Fan Clutch to Electric Fan OKCSuburban Suburban 1 07-02-2008 12:01 PM
Replacing clutch fan with dual electric fans. thebeastjuggalo Performance 11 12-23-2006 02:48 PM
Electric Fan vs. Clutch Fan tass81685 Sierra 1 10-20-2006 08:21 PM
Clutch Fan vs. Electric Fan MeNBabyD Durango 0 12-23-2005 03:22 PM
Would you swap belt driven fan for electric fan? highlandlake Rodeo | Passport | MU 2 01-28-2005 04:34 PM
