Old 05-04-2011, 11:01 PM
daprinna1 daprinna1 is offline
Angry 99 windstar issues HELP
I drove over a bump the other day and lost all control functions on dashboard, turn signal, hazard, fuel gauge, speedometer, oddemeter, temp lvl, but i did still have tail lights, head lights, blower (fan) and radio. The radio and lights stayed on even after the van was shut off. Also the only way to get the lights and radio to turn off without disconnection the battery i have to unplug the fem (front electronic module)?
Old 05-04-2011, 11:53 PM
Windstartled Windstartled is offline
Re: 99 windstar issues HELP
I'm assuming you have checked if battery connectors aren't loose? On my 2000 Winnie the connector to the negative pole had once become loose (but not disconnected outright) and this had caused the van to experience all sorts of weird electrical phenomenon: headlights stayed on even when switched off, or they would turn off but then taillights would come on instead, gauges "bounced", symphony of clicks would erupt from behind the dash, etc. and the engine would not start. Took me several hours to figure this one out.
Old 05-05-2011, 05:18 AM
Yes the battery connectors are fine. I also can not get my van to start now. I tried to start it when i got home it started fine the next day it would not start at all and still will not. Thought it may be computer related but spent 128.99 at autozone and had it flashed at factory still does the same thing.
Old 05-05-2011, 07:26 AM
This happened after you drove over a bump, I would suspect either something shorted or disconnected. Does the starter make any noise when you turn the key?
Old 05-05-2011, 03:32 PM
no nothing its like the starter went out but we can get it to try and kick over by the seloniode.
Old 05-05-2011, 08:00 PM
wiswind wiswind is offline
Verify the electrical connections at the starter.....including the ground connection.
This is a high corrosion area.
Is the battery maybe also going bad?
Check the connections on the back side of the power distribution box in the engine compartment, as well as reseating the relays and fuses inside it.
Try the same in the fuse panel under the dashboard......driver's side......as well as verifying that the plugs are secure.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 05-06-2011, 09:54 AM
I can get the van to try and turn over when i bypass the starter and just jump the selonoid. all fuses and relays are good when i checked them the other day
Old 05-06-2011, 09:55 AM
also it is brand new battery good charge even though didnt need new one got one anyway
Old 05-08-2011, 08:57 PM
so turns out that fuse number 16 was not quite blown but was causeing the issue now that fuse keeps blowing what could cause this?
94 Oldsmobile 98 Regencey Elite Issues HELP ME! nsman06 Ninety Eight 9 11-05-2009 08:23 PM
98 Ford Windstar issue jta1028 Windstar 4 08-19-2008 07:46 AM
96 Windstar transaxle issues... HELP??? Stites Windstar 9 05-14-2006 08:37 PM
'96 Windstar issues (thinking of buying) - tranny, windows, and AC voxecho Windstar 9 05-09-2006 11:53 AM
2000 Windstar Issues floydfam Windstar 3 03-11-2006 05:35 PM
