Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 05-02-2011, 03:36 PM
jg65483 jg65483 is offline
Send a message via Yahoo to jg65483
Fuel Pump
I have a 94 Ford Ranger Spash 4.0L 4x4. Were is the fuel pump located at? And does it have one inside the gas tank?
Old 05-02-2011, 03:53 PM
jdl jdl is offline
Re: Fuel Pump
The fuel pump should be in the tank. I'd use a gage and check fuel pressure, first. Then check voltage and ground at the fuel pump connector for the pump motor, engine cranking.
The Following User Says Thank You to jdl For This Useful Post:
jg65483 (05-03-2011)
Old 05-02-2011, 10:49 PM
toddler62 toddler62 is offline
Re: Fuel Pump
The pump is in the tank toward cab side of tank, If it needs to be replaced the easiest way to do it is to remove 3 screws around gas cap, so the filler tube is loose from bed, Take out tail lights and unhook tail light wire bundles from bed. Take out the six bed bolts Then get a strong friend and lift the bed off. The fuel pump sits right on top of the tank. Ive done it by dropping the tank from underneath. but unless you like eating dirt and spending extra time it took about 4 hours to take bed off compared to 6 for dropping the tank, Put the complete fuel pump assembly in which includes fuel guage sending unit and screen, Does'nt cost much more, A lot quicker
The Following User Says Thank You to toddler62 For This Useful Post:
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
