Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 05-02-2011, 12:40 PM
McLin's Avatar
McLin McLin is offline
No spark...
Hi,
my friend have an 92 Firebird with 3.1L V6 engine.
He drove to sport studio and then the car didnt start anymore.
After testing we found that there is no spark to plugs.
We changed the ignition coil but no spark again.
Is there another common problem what we can check?
Thx.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 05-02-2011, 01:14 PM
jdl jdl is offline
Re: No spark...
With dis ignition, if no spark at the plugs and no injector pulse, check the crank sensor.
If you have a distributor, engine cranking, use a testlite on negative side of coil, does it pulse?
Old 05-08-2011, 11:05 AM
McLin's Avatar
Re: No spark...
Hi,
today we looking for crank position sensor but I didnt found any. But we clean the distributor cap and module an use some WD40 and now we get spark, the engine rotates but is not starting.
Any other ideas?
Best regards McLin.
My Lumina
Mileage:
Old 05-08-2011, 11:43 AM
Scrapper Scrapper is offline
AF Premium User
Re: No spark...
Originally Posted by McLin View Post
Hi,
Any other ideas?
is it blue spark you get or more yellow of a spark because yellow not good.
Old 05-08-2011, 11:44 AM
McLin's Avatar
Re: No spark...
yellow What did I need new?
- Distributor Cap
- Distributor Rotor
- Ignition Pickup
But what is the name for the coil inside and the thing with the pins to the cap...?
Best regards McLin.
My Lumina
Mileage:
Old 05-10-2011, 03:11 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: No spark...
ignition control module is probably the culprit.
Old 05-10-2011, 03:12 AM
Genopsyde's Avatar
The President
Re: No spark...
if the tach doesn't move while cranking, the ICM is definitely bad.
no spark no spark NO SPARK!!!!!!!!!! javatrooper Cherokee 8 08-17-2013 11:02 AM
Spark, Fuel, But not fuel on spark plug? MoonChld454 Cutlass Series 5 05-02-2004 03:59 PM
No Spark at the Coil Pack/no spark to the plug wires crosscypher Off-Topic 13 02-04-2004 06:01 PM
Spark Plugs + Spark Plug wires ricodemus Engineering/ Technical 4 02-27-2002 12:23 PM
