Old 05-02-2011, 09:37 AM
l1driver l1driver is offline
Send a message via AIM to l1driver Send a message via MSN to l1driver
00 Silverado Headlights
I have a 00 Silverado Z71 4x4 with a 4.8. My head lights will not shut off.There is nothing blocking the sensor. when I turn the key on all my lights come on. I can override them but when I do my DRL's won't come on.
Old 05-02-2011, 12:22 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: 00 Silverado Headlights
Do your DRL's come on at all? Is it possible that they are burnt out?
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 05-02-2011, 12:26 PM
NO they were working fine, The headlights are coming on as soon as I turn the key on. Doesn't matter whether it's Day or Night.
Old 05-03-2011, 09:11 AM
j cAT j cAT is offline
I don't have the exact answer.. I would suspect the sensor that produces the signal to the BCM to operate these headlights when it gets dark out. my vehicle over time now puts the headlights on when it is not all that dark out ..
did this suddenly occur ???? if so it may be a relay in the BCM.
Old 05-04-2011, 12:10 PM
Problem solved, Turns out it was the Ambient Light Sensor on the dash. Got a new one from the dealer ($13.82) replaced it. Everything is back to normal. Thanks to everyone for your help.
Old 05-04-2011, 12:25 PM
thanks for that detailed info..perhaps I'll replace my sensor since these headlights come on too soon..
Old 05-04-2011, 12:31 PM
Yeah, It was fairly easy to do. Sad part is if the wire was about 6 inches longer you could do it with out taking the top of the dash off.
Old 05-04-2011, 02:29 PM
thanks for that info ! the lens has most likely gotten damaged , like the headlight lenses..
2001 Silverado - headlights dim when not accelerating? Faze3 Silverado 17 10-08-2004 08:17 AM
Silverado - Headlight problem Mike555 Silverado 2 10-02-2004 06:26 AM
'01 Silverado headlight issue azsilverado Silverado 5 08-19-2004 07:24 AM
2001 Silverado Headlights don't work !!! Mannysalv C/K 12 05-25-2004 11:36 PM
1997 Silverado headlight knob fell off ridley C/K 0 12-19-2003 02:17 PM
