Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-01-2011, 08:05 PM
skip15 skip15 is offline
rear abs sensor bolt rounded
I went to replace my rear abs sensor and found the bolt is rounded how can i get it loose any ideas
thanks
Old 05-01-2011, 08:37 PM
FishFind FishFind is offline
One Hot Shot
Re: rear abs sensor bolt rounded
what kind of car? you can try to use a grinder and cut a slit in the middle and use a large flat head screwdriver. Careful if you cut to far it will just split in half when you apply pressure.
Old 05-01-2011, 09:18 PM
tempfixit tempfixit is offline
Can you get a vise grip on the bolt????
Old 05-02-2011, 06:03 AM
it's a sportrac and there is not much room ford put to fins on each side
of the sensor and can't get vise grips it also is on the top of the rear pumpkin
How to replace rear abs sensors boilerman Windstar 1 03-03-2005 12:12 PM
1996 4wd Blazer where is rear ABS sensor? scholzee Blazer 1 11-08-2004 08:17 PM
91 Bonneville rear ABS sensor essikr Bonneville 0 10-23-2004 10:11 AM
Left rear ABS sensor for 97' Acura CL 3.0 Dprough Introductions 1 12-03-2003 03:03 PM
Rear ABS sensor on 95 legend fettie g Legend | RL 0 10-22-2002 09:21 PM
