Old 05-01-2011, 05:26 PM
Ccoleman912 Ccoleman912 is offline
Ford f150 installing fuel injector
My 1990 ford f150 Was skipping I found that some squirrels had chewed my wires. I fixed the wires. Still skipping... Its got new spark plugs and cables. I think it might be an injector. How do you remove one and put a new one in?
Old 05-01-2011, 07:17 PM
jdl jdl is offline
Re: Ford f150 installing fuel injector
You might try a cylinder balance test? Engine idling, Kill the cylinders one at a time, The cylinder that you kill that has the least effect on rpms is a dead or weak cylinder. Then you check spark--fuel--compression. Any applicable trouble codes?
Old 05-30-2011, 03:15 PM
Greg5150 Greg5150 is offline
Most fuel injectors have a tiny micro basket filter installed in the top of the injector. I've seen these get clogged with crud and because they are so small it does not take must to completely or partially clog them. You can see these filters here: http://www.ecrater.com/p/10991905/bo...keywords=bosch type. I like to replace these filters. They are pressed in but it is easy to get them out and install new ones. Also, you should replace the injector orings whenever you remove and install injectors.
Ford Tuarus - are multiple problems related? kevinbryant2011 Taurus | Taurus Wagon 1 04-28-2011 09:17 PM
2003 Mustang GT - Injectors & MAF?? ndean52 Performance 1 05-03-2010 11:26 AM
1990 Ford F150 - Flooding? mizshadow420 F Series 1 02-04-2010 08:03 PM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 01:06 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
