Old 04-30-2011, 08:36 PM
302Z28 302Z28 is offline
Idle solenoid
Is there any method of testing the idle solenoid or signal from the ECM on a
'92 Metro? My engine still drops about 150 rpm as electrical accessories are turned on. The biggest drop occurs when the headlights are turned on. The alternator keeps the battery charged, so I don't think it is a problem. The solenoid for the A/C works fine. The idle speed has dropped as low as 750 rpm and is very rough at that speed. Starting to wonder if the motor mount isolator bushings are bad the way the motor shakes at the lower rpm.
Any suggestions will be greatly appreciated.
Thanks,
Old 05-01-2011, 04:11 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: Idle solenoid
There's a separate circuit that raises the idle when an electrical load is turned on, but I think it uses the same idle control system. Some cars have an Idle Air Valve and some have an Idle Control Motor. Yes, there are test procedures in the FSM.
All that being said, I think the early cars are supposed to idle at 750. Low and rough idle is usually a burned valve, compression test is in order.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 08-11-2011, 08:38 PM
mr.Hand mr.Hand is offline
Re: Idle solenoid
so is the idle speed listed under the hood the idle speed without any headlights or accessories turned on? I've always wandered that
when i turn on my headlights my idle will drop, then go back up. is this normal?
Geoff
tcc solenoid problem 95 k1500 4l60E coreman30 C/K 6 01-26-2011 02:18 PM
95 k1500 wont shift into 2nd.. found melted solenoids coreman30 C/K 9 01-18-2011 04:24 PM
'96 Camry 4-cyl 2.2L Idle Control Sensor Maulana Camry/Camry Hybrid/Vista 4 03-18-2010 10:29 AM
1996 Grand Am 3.1; No Power to Starter Solenoid/Relay sgusmeri Grand AM 6 01-26-2010 12:42 AM
Transmission Control Solenoid Cheech43 Ram Pickup | Ram SRT10 2 03-27-2009 04:36 PM
