Old 04-27-2011, 03:02 PM
jaygio31 jaygio31 is offline
upper lower manifold question
I think i may screwed by my mechanic. My 3.8L 2000 winnie was leaking coolant. the line running through the lower manifold need to be replaced. upon inspection my lower manifold had a crack and needed to be replaced. he told me he had a used one from a van that blew the tranny and person was not fixing it. i had asked him to do the new iso bolts also. as my cel came back on 171/174/0401 i was wondering if he replaced iso bolts. when i now look at the upper intake the 13 bolts are still very dirty/rusty with no markings at all on them. i was wondering if he put the other vans upper and lower in my van assembled together, is that possible. the bolts dont seem as if they were touched
Old 04-27-2011, 08:07 PM
catvents catvents is offline
Re: upper lower manifold question
You have to remove the upper plenum section to gain access and replace the isolator bolts. And to replace the coolant tube it is necessary to remove the isolator bolts to lift the lower plenum section which give you access to the coolant tube. If you can take a look to the following link you will see all the process to fix the 171/174 issue plus this coolant tube replacement.
http://leckemby.net/windstar/windstar01.html
2001 Windstar
2007 Pontiac G5
2004 Freestar
1999 Ranger
Old 04-27-2011, 09:40 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Maybe, maybe not.
FIRST OF ALL make sure the vacuum hoses are properly connected at the back of the intake manifold, if they don't will cause a massive vacuum leak (p0171/174) and the EGR flow (green nylon tube running from the manifold to the EGR valve) will be affected as the EGR valve is not opening due to the lack of vacuum (p0401).
You can try to either run your hand to the back of manifold and guess only by touching at the back of the manifold (there should be 3 or 4 hoses connected to it) or you can try removing the wiper cowl and take a good look at the back of the engine.
Regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Lower and upper intake manifold gasket, help! The Unknown 7 Grand Prix 47 04-25-2009 02:39 PM
Cleaning lower & upper intake manifolds Triple G Windstar 1 03-25-2008 02:37 PM
93 PA upper intake manifold question sleo33 Park Avenue 3 02-27-2007 03:38 PM
Upper intake manifold question budbowl7 Tahoe 0 01-15-2006 05:58 PM
stillen port and polished upper and lower manifold/ Worth the money??? igota20hpweedeater 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 07-03-2004 06:48 PM
