Go Back   Automotive Forums Car Chat > Chevrolet > Colorado
Old 04-25-2011, 11:46 AM
mahan4444 mahan4444 is offline
A box or module under driver seat got wet. WHAT DOES IT DO?
2005 Chevy Colorado, 4WD, manual, 4cylinder
I had about 2 inches of water standing under my drivers seat from a heavy rainstorm. Some little electrical box or module is soaked and some corrosion. It doesn't have yellow stickers on it so I don't think it can be airbags but it might be a SDM. The part numbers on the unit are non existent on the WWW and I called the dealership and they aren't sure what it is. The 4WD push button panel on the dash does not work and the truck seems to be stuck in 4WD low. Fuses look ok. Actuator works. Completely baffled at this point. I have pics of the unit if you want to see. "writetopaulhotmail.com" thanks for your help lads
Old 04-25-2011, 06:00 PM
Stingray11 Stingray11 is offline
Re: A box or module under driver seat got wet. WHAT DOES IT DO?
That is your transfer case control module (TCCM). Your SDM is under the center console.
BTW, if you need a new TCCM there is no programming or setup required of the new one. Should just be plug and play.
David
Drivers Seat iamlocals How-To's and Walk-Through's 0 02-23-2009 12:29 PM
Wet Floor Under Driver Seat tictiv Camry/Camry Hybrid/Vista 11 09-06-2007 02:31 PM
Box under driver seat yumsbpa XL-7 1 09-03-2005 02:25 PM
Black box under drivers seat BEATUPESCORT94 Escort 4 07-26-2005 11:39 AM
Tags
4wd , airbags , drivers , sdm , seat
