Old 04-23-2011, 04:26 PM
KairoCross KairoCross is offline
Subwoofer question
So i set up my first sub,
12 inch kicker 350 peak.
Its been in my car for 5 days and ive
been messing with the settings for more
bass.
When i first turn on my car in the morning
my bass is pounding like i want it to be, but
after driving for about 10-15 minutes the bass
suddenly gets really quite and i cant really
adjust the settings anymore to make it louder,
any suggestions?
Old 04-23-2011, 08:11 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Subwoofer question
one of two things is happening, either your hearing is getting used to the volume or (more likely) the amp is heating up from being driven so hard and is going into a protect mode until it cools down. How is the amp mounted ? does amp have a fan on it ?
Old 04-23-2011, 11:26 PM
The amp is sitting on the carpet beside the sub box,
and there is no fan on this amp
Old 04-24-2011, 04:10 PM
Audio Guy
you probably have the gain set up too high, the gain or sens knob on the amp is NOT a volume control. It is desgned to match the amps input to the headunits output. Any bass level knobs or EQ's on the amp will be similiarly problematic. The amp will only put out so much, my guess is that you are wanting too much bass out of this setup. Having the sub in the correct box will also help a lot. A fan might help a little, wire a relay into the amp turn on lead to power the fan.
Old 02-16-2012, 07:12 PM
fluxmann fluxmann is offline
hello! first sub install! just got a new head unit. there is just 1 rca plug for the sub coming out of the head unit. not sure what to use! a splitter? thanks for your time.
Old 02-18-2012, 07:53 PM
Audio Guy
a sub is single channel anyway, either get a 1 channel amp or bridge a two channel one - it's pretty much the same.
Old 02-28-2012, 12:09 PM
i still have 1 plug coming out of head unit and need 2 at amp? what kind of cable would do that? thanks for your time!
Old 02-29-2012, 05:04 PM
Audio Guy
looks like the cable on the bottom, it's called a y-cable
http://www.cablewholesale.com/specs/...10r4-21103.htm
Subwoofer questions.. 3000GT4ME 3000GT/Stealth 5 05-16-2004 03:16 PM
Subwoofer Question??? PunsIntegraLs Integra 0 08-24-2003 06:51 PM
Subwoofer question DMC12 Car Audio 15 04-28-2003 11:27 PM
subwoofer question custom95civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-16-2002 07:16 AM
