Old 04-23-2011, 10:57 AM
MassGTP MassGTP is offline
Idle dips stalls sometimes in park.
Went to start my car this morning and put it in reverse and the rpm's dipped almost to the point of stall. Then it jumps back to normal. So I leave it sitting idling and every 2 min or so it would dip and level off at 700rpm. I pulled the maf and cleaned it pulled the other top tb sensor not sure what its called, and that one was a bit dirty. So I cleaned that one too. Restarted and it stays on and doesn't stall but if i put it into gear it will bog down and want to stall.
Any ideas, I did a search and that was how I knew to clean the sensors but that didnt seem to work.
2000 GTP
140,000
Old 04-23-2011, 11:27 AM
FishFind FishFind is offline
One Hot Shot
Re: Idle dips stalls sometimes in park.
how does it run if you leave it in park and give it more gas?
Old 04-23-2011, 11:57 AM
Sometimes when i put it in drive it seems ok, then i drive 2 seconds down the road and it kindo of acts like its low on gas and dies. But i just put gas in it so I know its not that. But im stumped, guess it could be the 02 but not sure. I cleaned all the tb sensors and checked for vac leaks. Nada
But when i leave it in park it idles ok for a bit then just bogs and revs to catch itsself then eventual dies. But i will start it right up and it seems fine for a bit, then repeat the same shit. Giving it more gas it doesnt choke or anything, seems to rev fine.
Old 04-23-2011, 12:40 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Try disconnecting the harness to the MAF and start the engine with it disconnected it might stall the first time, just start the engine again and see if the problem goes away.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 04-23-2011, 02:19 PM
Ok, I unplugged it and it seem to run ok but same issue. After 2 min of idle it drops and revs to catch its self and eventually dies. But it didnt drop as much as with the sensor plugged in.
Old 04-23-2011, 03:40 PM
I tried the fuel pump resister trick bending pin 85 to put it in high speed mode and it seemed to work. Hasnt stalled or bogged yet. So what does that mean is going? the fuel pump?
Old 04-23-2011, 06:57 PM
olopezm's Avatar
I'm not sure what's the problem with it (I own a GT), only thing I know it's related to the fuel pump resistor. There is a rewiring kit available at some autopart stores.
Old 04-23-2011, 07:14 PM
Thw fuel pump trick didnt work, stalled on me on the way home anytime i didnt have my foot on the gas, stalled even as I was driving or cruising at that matter. Any other ideas?
Old 04-23-2011, 08:05 PM
One Hot Shot
check your fuel pressure.
Old 04-24-2011, 07:53 PM
Replaced the MAF today and the problem seems gone.
Thanks for your help guys!
~Joe
99 Caravan Sport Rough Idle and Stalling blase Caravan | Voyager 8 10-10-2010 08:48 PM
2000 Grand am se...bad idle and stalls weis_01 Grand AM 3 09-20-2010 12:50 AM
95 tsi really low idle and stalls.. Please help please Brenthb25 Eclipse Problem Diagnosis 3 07-20-2010 11:41 PM
'92 Seville stalls at idle - lockguy Seville 2 06-20-2010 10:40 AM
fuel smell in car and stalls sometimes? HELP mark4674 Taurus | Taurus Wagon 0 12-19-2009 08:08 PM
