1998 K1500 w/P0420 code
I have a 1998 K1500 with approx. 181,000 miles on it. I have a INNOVA CanOBD2+ABS diagnostic scanner tool. I ran the diagnostics on it and it came up with a P0420 code.
I already know the possible problems. My scanner came up with some numbers. They are as follows: CALC Load (%) 2.7 ECT (F) 188 (this is engine coolant temp) STFT B1 (%) -1.5 LTFT B1 (%) 6.2 STFT B2 (%) 0 LTFT B2 (%) 3.9 MAP (inHG) 10.9 Eng RPM 547 Veh Speed 0 MAF (lb/min) 0.871 TPS (%) 0 Im not sure if these are "good" values or not. Ive searched all over the internet trying to figure if these are within limits or not. I do know what most of the abbreviations are but not sure if the numbers are good. This truck has 3 o2 sensors. 2 upstream and 1 downstream if i remeber right. At $75 dollars a piece i dont want to throw parts at it. Cat converters are quite spendy as well. Any help would be appreciated. My truck does run a little rough and have noticed a slight drop in fuel mileage. Other than that it seems to be normal. Thanks Mike |
Re: 1998 K1500 w/P0420 code
Have you cleared code and see how long it takes to come back.
I main cause of cat code is engine not running right. When was your last good AC delco tune up? Any cold air intakes or K & N filters bosh plugs programers on it? Any other codes? To see what engine running and fuel trims and 02 sensors are doing you have to watch scanner readings on the road AT A GOOD STEADY SPEED after it has been drove 15-25 minutes. Watch fuel trims on both sides for even and low trims. Watch the 02 sensor readings into and out of cats. After engine tuned up and running good and make sure fuel pressure is up to specs. If both readings the same you cat has bit the dust/ Kicked the bucket on the last 7 life.
As to the scanner sensor readings a good start is with reading the scanner instruction manual.
A all data DIY online subscription covers all codes and repair flow charts for codes and should have proper sensor readings and adv on them. Will cost about 25 $ first sub but will pay for itself many times.
this usually means the converter is defective. replace the down stream O2 sensor. this could be at the end of its life. the other items that can cause this would be the upstream O2 sensors are out of spec and caused the converters to fail. the O2 sensors are good for 100,ooomiles. then they start to get out of spec causing the engine to run at the wrong fuel mixture.
since your intake manifold vacuum is low I would guess with the symptoms your engine has it is a restricted exhaust [cat converter] ... with a vacuum guage hooked up at idle vac should be 17-21 in ...rev engine to 2,ooo rpm does the vac drop and stay low ? it should drop and then rapidly rise to 17-21 in if good.. remove the upstream O2 sensor leave hole open go for test drive also do the vac test as above see if it is now good.. |
Just wanted to add that i had replaced exhaust behind the Cats. New mufflers and pipes.
I cleared the code last night and have driven it around town and on the interstate for about 20 miles. It seems to run real good. Nice acceleration no hesitation throughout all ranges. Could this have been the problem. I only had one fault code and it was P0420. No others. My old exhaust had a leak at the flange behind the last cat going into the muffler. And the muffler was shot. Thanks everyone for the replies. Mike |
looks like you found it ..also with exhaust leaks this can messup the engine management and cause low MPG ....you should find a better MPG/power now.. good luck thanks for reporting your findings/results. |
