Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 04-21-2011, 07:29 PM   #1
barteldt
Send a message via AIM to barteldt Send a message via Yahoo to barteldt
2001 2.2l cuts out with less 1/4 tank
anyone had this problem my 2001 cav 2.2 l runs just fine with proper amounts of gas but once it gets to about 1/4 tank it will cut out on sharp turns normally left seems to set it off and going up hill too but i think its the hard left turns more than the going up hill it doesnt normally die if i just let up and wait a few seconds it takes off again doesnt seem to be back firing more like starving for gas
barteldt is offline   Reply With Quote
Old 05-28-2011, 10:15 PM   #2
J-Ri
J-Ri's Avatar
Re: 2001 2.2l cuts out with less 1/4 tank
The fuel level sensors in Chevys are known for going bad, I would guess your gauge is off, and you actually have less than 1/4 tank. So you're probably running out of gas going up hills and turning. My sister had a '96, and she let it get so low that when parked in my parents driveway it wouldn't start. I rolled it out into the street (mostly level) and it fired right up.
When I fill my '04 from 1/4 tank on the gauge it takes about 9-10 gallons (to my knowledge, the tank capacity on '96+ [and maybe older] is 12 gallons, I know '04 is 12 gallons). Your owners manual probably says what your car is. Fill the tank from 1/4 and see how much it takes. The pump is also cooled by the fuel, so if you determine that you are running out of gas, be sure to keep at least a few gallons in the tank or the pump will burn out. The good news there is that the fuel pump on these is an assembly that contains the level sensor, so if the pump goes bad, there's a 99% chance replacing it will fix the gauge problem.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
96 Toy Camry LE 2.2L 5S-FE parts needed Maulana Classifieds 0 03-18-2010 01:17 AM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 08:13 AM
2001 2.2L cylinder 4 misfire little big rig Problem Diagnosis 4 06-24-2008 05:33 PM
2000 V6 Rocking Accel with Less Than 1/4 Tank of Gas tomdoss02 C/K 1 02-25-2004 12:41 AM
Can I get a 2.2L fuel pump for less than $300? WhiteCavaliac Cavalier 1 10-29-2003 05:13 PM
