Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 04-20-2011, 11:22 AM
KnobbyTires KnobbyTires is offline
Exclamation FORD's SELF-DESTRUCTING 4.0L V-6
MY 99' Ford Ranger is having trouble at 99K. (So did my last one, a 2000, at 94K, whose heads warped and cracked without notice, or overheating, only a once a month slight need to add water)
ENG LIGHT is ON... Trouble codes are:
P0171 - Fuel trim bank, one position (rich or lean bank, O-sensor, injector, misfire, fuel pressure, MAF
P0174 - Fuel trim bank, two position (MAF, fuel pressure, O-sensor, misfire, injector, or engine mechanical
PO304 - Misfire cyl 4, (plug, wires, vacuum, injector, hi/lo fuel pressure)
P1507 - Idle-Air-underspeed error (possible vac leak, IAC valve, Inlet plug, open or shorted electrical circuit
To get through emmisions, I added 4 bottles of Heet, and one Octane Booster and it ran fine. The check engine light even went away on it's own.
Where would you start? My only symptom really is rough at cold starts, takes a long time to warm up, runs smooth over 2,000 RPM when warm, and almost normal below.
Your two-cents worth please:
FS: 1991 Jeep Cherokee, 4.0L Inline 6 Engine with 104,000KM! spookykl General Discussion 0 08-03-2006 09:03 AM
'04 4.0L V-6 Engine Cost Eye Of Apocalypse Ranger | Courier 2 10-15-2004 05:35 AM
4.0L V-6 from a 2004 Ford Ranger Eye Of Apocalypse Ranger | Courier 5 04-20-2004 10:24 PM
4.0L Inline 6 87ttopGT5.0 Cherokee 2 01-10-2003 09:10 PM
4.0L Inline 6 87ttopGT5.0 General Discussion 0 06-06-2002 10:47 PM
