Old 04-19-2011, 02:29 PM
claytonduk claytonduk is offline
'03 tb fuse for battery
hello, I'm having issues with my instrument cluster possibly causing my battery to go dead in about 24hrs. Is there a fuse to take out that will disconnect the battery so I dont have to disconnect the negative terminal? thanks for any help!
Old 04-19-2011, 06:31 PM
maxwedge maxwedge is offline
A990 racer
Re: '03 tb fuse for battery
There is no one fuse to do that, there is a fuse for the cluster in the box under the rear seat.
Old 04-24-2011, 10:35 PM
I ended up taking out the 24 fuse in the engine compartment fuse box and the battery doesnt go dead. I tested the orange and red wires on the plug for the instrumant cluster and both had 12V. the grounds also tested good(black and black/white). Does anyone know how to test the male receptacle on the instrument cluster, if there is a way? thanks
Old 04-27-2011, 06:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Just 12 volts to it does not tell you if it is pulling amps or justbhas voltage to it.
You need to get a amp draw meter and test the orang wire for pulling amps key off.
post back how many amps is pulling.
Then unplug dash cluster and see how many amps it is pulling.
There may be something else tied on/shorted to that fuse circuit.
MT
2006 Grand Prix Battery Drain wratchetjaw Grand Prix 9 12-20-2010 04:18 PM
95 Jeep Grand Cherokee Radio Fuse Keeps Blowing - Dead Battery ajcool Grand Cherokee | Grand Cherokee SRT8 1 04-25-2010 10:30 PM
D/C Cut FUSE??? 2002lexusls430 General Discussion 1 01-10-2010 04:14 PM
drivers side fuse block redka88 Lumina 0 07-27-2009 09:14 PM
IOD Fuse draining battery BoChi Caravan | Voyager 0 10-06-2004 01:30 PM
