Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-19-2011, 01:35 PM
budscuz budscuz is offline
misses. code 0300
This one is running me in circles. Firstnoff, she's got no power to pull a hill. Check engine light flashes. Reading codes i get missfire on cylinders 1 and 4. After cleaning and jockying plugs, she runs smooth until pulling a steep grade. Now the code reads 0300 for multiple misses. Also, each time I check codes, it reads 1406 for the EGR valve input high. Will missing cause the EGR to malfunction, or vice verse? Any help on where to go with fixing this would be helpful. THX
Old 04-22-2011, 09:08 PM
eippermx's Avatar
eippermx eippermx is offline
Re: misses. code 0300
Swap the coil (cheap). If that doesn't work. Then it's the ignition module located below the coil pack. As far as the EGR, its probably dirty, unbolt it, clean it, slap a new gasket on it.
mark
Love my Pontiacs!
'04 GP GT1
'02 Bonneville
'98 GTP - 2 dr
'98 GTP - 4 dr
'99 GP "Flaming Tomato" GT
Last edited by eippermx; 04-22-2011 at 09:14 PM. Reason: Forgot to adress the EGR.
Old 04-28-2011, 12:46 PM
thanks for your input, Mark. Now I got another dillema...how do I get the carbon build up out of that egr? My book says no chemicals, but I tried B-12 anyway and that ain't gettin' it done. Thanks for your help...again.
Ken
Old 04-29-2011, 07:33 PM
Checked the coils with my ohm meter. The 1/4 coil is definitely open. Tried brake parts cleaner and that didn't disolve the carbon deposits either...Thanks for the help, gentlemen. I love this car...I'll be keeping it in excellent shape.
Old 05-05-2011, 09:57 PM
The 1/4 coil was open. replaced it and runs sweet again. No egr problem...Away we go!!!
97 Rodeo codes 0300 and 1133 hitnmiss Rodeo | Passport | MU 4 07-15-2007 11:13 PM
Engine misfire? Code 0300 9999 Camaro Discussions 3 08-13-2006 10:39 PM
96 blaz- error code 0300, 0306, 0303 - TBI steveblazernut Blazer 8 08-14-2005 10:14 PM
SES Codes 0300, 0141 HELP Again PLease mushhhy Blazer 19 05-15-2005 08:34 PM
code 0300 flashes under load phantastic1 C/K 5 05-06-2005 09:32 PM
