Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-17-2011, 08:11 PM
mylows10's Avatar
mylows10 mylows10 is offline
99 tahoe no spark or start
ive got a 99 tahoe that wont start ,was running earlier ,but now wont start.engine will turn over , just wont fire.changed the coil,cap ,rotor, and crank sensor , but still no spark.checked fuel and pump both are ok.pulled #1 spark plug and no spark.also checked to see if distributor is working properly,seems to be ok .now im stumped .any suggestions please
1995 s10 ls
2-12 ascendant mayhem woofers
dc 7.5
pioneer avhp 4100dvd
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
dc 175.4 4 channel amp
152.8 db certified loudest truck on the westcoast without a wall or blowthru and 2 batteries
Old 04-17-2011, 09:34 PM
777stickman 777stickman is offline
Re: 99 tahoe no spark or start
Need to check for 12v at the coil with the key in the run & start positions. If you don't have it, it could be an Ign Sw issue (common) or wiring or fuses.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-17-2011, 10:47 PM
mylows10's Avatar
it was coil and ignition mod but now it runs rough and check engine light is on
1995 s10 ls
dc 7.5
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
Old 04-18-2011, 09:44 AM
I see you replaced the crank sensor. This usually requires a "crank variation learn" procedure. Needs a high end scan tool in the hands of a knowledgeable technician.
Also with the CEL on there are active codes. What are they?
57 Chevy 210
Old 04-18-2011, 11:48 AM
mylows10's Avatar
Put old crank sensor back in still runs. Runs fine over 70. But under sputters and back fires. Pulled number 1 plug looks like engine has been running lean for some time. Going to replace plugs and wires and scan code
1995 s10 ls
dc 7.5
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
No Spark - Replaced all sensors shnicht763 Cavalier Problem Diagnosis 4 04-30-2010 08:48 AM
94 3000gt not sparking shaggy3000gt 3000GT/Stealth 5 11-14-2009 07:30 PM
2001 Olds Intrigue 3.5 No Spark tyler219 Intrigue 2 06-04-2009 12:48 PM
97 Tahoe won't start. Cranks, has no spark rookieshaper Tahoe 2 02-24-2009 09:40 AM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
Tags
problem , spark , starting , tahoe
