Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-17-2011, 05:53 PM
95redTA 95redTA is offline
Air conditioning looses pressure when off
2000 v6 camaro
Ok so i charge my ac to the correct pressure, works fine blows really cold air vie taken 10 hr drives and it work fine the entire time doesn't loose any pressure. After the car is turned off for a few hours all the r134a leaks out. Haven't got a uv light to see where Yet anyone have any idea where it would be leaking from since it only does it when the car is off
Old 04-17-2011, 06:19 PM
j cAT j cAT is offline
Re: Air conditioning looses pressure when off
Originally Posted by 95redTA View Post
2000 v6 camaro
if all the refrigerent leaks out you must be able to see the oilon the ac piping or at the compressor shaft seal..did you install the pag 150 oil ...if it has leaked this bad you will need to add at least 4oz of this oil.
how long did you vacuum pump the system ? pressurize the system and spray soapy water on the ac components/fittings.
to reveal leaks...condenser coil at front of vehicle can get damaged from rocks etc...
Old 04-17-2011, 07:06 PM
brcidd's Avatar
brcidd brcidd is offline
Compressor shaft seal is number one location for leak, compressor belly is number two.....compressor is resealable- kits available online, and tools available-- but most opt for new compressor-
Confirm leak area first- look for the drips and spray pattern outside of clutch on compressor.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-18-2011, 09:20 PM
Well put uv die in it but no luck with that couldn't find any leaks but It was finally quiet and I can hear it leaking from the compressor when the car is off and if i spin the compressor clutch the hissing sound gets faint/loud depending on where I turn it which would explain why it doesn't seem to leak when it running but leaks rapidly when car is off cant figure why the die isn't showing
Old 04-18-2011, 09:26 PM
brcidd's Avatar
You definitely have a worn out shaft seal- those single lip seals do that-- double lip seals were not OEM until 2002 model year....
The dye will eventually show itself-- you need the black light and UV glasses to see it good though....
If it were mine, I'd reseal it- but I do them all the time...It would be tough for a newbie to get it right on the first one- and have to have the proper tools as well.
'99 GMC Yukon
Old 04-18-2011, 11:23 PM
Yea Im just going to replace it along with the accumulator hope the parts get here soon
Florida+black camaro-a/c= Gates of hell
Old 04-23-2011, 03:19 PM
replaced compressor works great now
206 Air Conditioning Carl.I 206 2 09-18-2014 02:19 PM
96 grand voyager no air conditioning question proserver Caravan | Voyager 5 08-21-2011 01:45 PM
2003 Alero quits with air conditioning Stefphelps Alero 3 04-29-2009 07:16 AM
Air conditioning recharge Sentax '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-24-2009 10:25 PM
