Go Back   Automotive Forums Car Chat > Toyota > LS400/LS430/Celsior
Old 04-17-2011, 12:56 AM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
New to me 92 LS400
Got a steal on a 92 LS400, $3,200. Only 112,000 miles and in great shape. It does have a couple of concerns.
1. Everytime I turn on the aftermarket CD Player, i hear the antenna motor running in the back, but the antenna won't come out. I'm worried that this will burn up the motor before I can fix the antenna. What causes this and how do I fix it?
2. I don't know if the switch for the suspension height works. It doesn't seem to change anything when you push it. The light on the instrument panel keeps flashing the 'NORM' indicator.
3. The LCD screen that tells you the time and climate control temp doesn't work. Is this common?
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Old 04-23-2011, 12:09 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: New to me 92 LS400
1) Sounds like the toothed plastic strip that is attached to the antenna is broken. You can pull out the antenna and open the motor assy to remove the broken strip. A new antenna can be fed in easily...there are aftermarket ones for $15. Read the directions to install it.
2) Do you hear anything when you first start the car? Electric motors running or hissing? If so, you may have an air leak in the system. If not, the compressor may be bad.
3) If it's like my '92 Camry's LED clock that fades in & out, yes it's somewhat common. But a warning that the sensor doesn't work means that either the ground is bad to that sensor or the sensor has gone bad.
I don't claim to know everything about this car, but these are the more common reasons for Toyotas in general.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-09-2014, 11:27 PM
Wow...this is probably the first time I've logged in since I posted this.
Sold the car a few months ago after the water pump and timing belt gave out, the A/C had died, and a myriad of problems.
(eBook) Buying New and Used Car Tips schumi_reloaded Car Buying Q&A 2 06-05-2009 12:18 PM
new aftermarket parts for sale tommy67 Parts for Sale 1 04-24-2009 02:34 PM
New Feature '97ventureowner Cars/Parts for Sale/Exchange 0 02-19-2009 11:21 PM
LS400 vs. Q45 autofan LS400/LS430/Celsior 24 09-30-2003 02:28 PM
Programming Keyless Remote LS400 chadmaisel LS400/LS430/Celsior 4 10-02-2002 11:29 PM
