Go Back   Automotive Forums Car Chat > Triumph > TR6
Old 04-16-2011, 11:12 AM
Kincaidllc Kincaidllc is offline
Fuel pumping out of carbs
I just purchased a 1974 TR6 that has been sitting in storage for past 20 years. I made sure engine was free, put in a new battery and points. The car started right up (air cleaner is off) but fuel is pumping out of one of the top ports on upper left side of throat on each carb. I am unsure if this is a stuck float or? Anyone have any idea what the cause is and what my fix is --- the car ran fine so I was hoping to prevent a complete carb rebuild. Thanks
Old 04-16-2011, 11:52 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Fuel pumping out of carbs
You have SU carbs on this, right?
Rebuild them. Chances are there is a lot of dried gum, varnish, deposits and corrosion all over the insides of the carbs that mess up not just the floats, but also the vacuum pistons, which must move freely and properly for proper jetting and performance.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
