Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-15-2011, 07:05 PM
sammyb078 sammyb078 is offline
Question 1994 Dodge Dakota???
I will be driving along the truck will shut down. There is no fire or fuel going to the motor.
I have changed the crank sensor, mass air flow, throttle positioning sensor, fuel/ air sensor, plugs, wires, distributor cap, rotor button, distributor shaft, switched out computers and coils with an identical truck.
Checked the Auto shutdown relay and fuses everything is working fine.
I can't figure out why the computer is telling the truck to shut down the fuel and fire.
Where is the sensor located on the truck that would make the computer think there was a rear end collision or roll over???
Next step is dropping the gas tank to see if there is a bad wire or faulty ground....
Please help I am ready to stick a for sale sign in her and let her go....
1994 dodge dakota hotrod1976 Dakota 1 09-04-2009 11:48 AM
1994 Dodge Ram Van 15 Pass... Electrical? MeadowLark8 Ram Van 3 04-09-2009 09:20 PM
1994 dodge dakota motor swap...help chris172 Dakota 6 10-08-2007 09:17 PM
1994 Dodge dakota rebuild Powellds Dakota 0 05-20-2005 08:46 AM
1994 Dodge Dakota Transmission problem Gcain Maintenance 0 03-15-2005 08:41 AM
