Old 04-15-2011, 12:03 PM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
79 truck is calling for help
got a 1979 350 4bbl scottsdale that we just from the gf dad put a diff carb on it that we rebuilt (quad puke) but now there is gas mixing in with the oil thought i smelt some before but cant remember ( before carb swap) need help
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
Old 04-16-2011, 01:33 PM
Schurkey Schurkey is offline
Re: 79 truck is calling for help
1. You screwed up the carb rebuild. Float too high, wrong float, needle 'n' seat not actually sealing, carb well plugs leaking, etc.
2. Defective engine-mounted fuel pump. Common problem when there's gasoline in the engine oil. Usually also means that the fuel delivery to the carb is poor, leading to poor power, stalling, TERRIBLE fuel mileage, etc. Depending on the severity of the fuel pump defect, you may see fuel spitting out of the vent hole in the fuel pump; often it washes away the dirt on the frame/crossmember and so part of the evidence that the pump has shit the bed is a CLEAN spot on the frame aligned more-or-less with the fuel pump vent hole.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-16-2011, 06:33 PM
j cAT j cAT is offline
with the engine running see if gasoline is leaking into the engine looking into the carb..
I suspect if the engine is not blowing out black smoke when running it is the fuel pump..remove pump and inspect ....
alcohol in gasoline and these old vehicles is big trouble with the rubber fuel components and the steel tanks..the carb filters need lots of replacing..
Call 570-815-4697 For Help With Your Neon ButtPirate33 Neon | Plymouth Neon 1 01-07-2008 11:03 PM
Call for help - cruise control not shifting down curtishall Ram Pickup | Ram SRT10 1 06-14-2006 01:34 PM
Calling engine swappers for help drvngstorm05 Camaro Discussions 9 04-07-2004 03:46 PM
