Old 04-15-2011, 10:08 AM
bsr2002 bsr2002 is offline
Question Overheat
I'm driving on freeway about 30 miles from home everything is fine, when I get off ramp and stop at the light I notice my temp gage moves up like it wants to overheat...When I get back on the freeway ti goes back down.
Thermostat maybe???
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 04-15-2011, 11:18 AM
inafogg inafogg is offline
Re: Overheat
i dout its the thermostst. have you check radiator level?
are the cooling fans working?
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-15-2011, 01:10 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Re: Overheat
I would be happy to look into this further for you. In order to do so, I will need the VIN for the vehicle as well as the current mileage. Please feel free to contact me via private message if you would like. I look forward to hearing from you. Thank you.
Tricia, GM Customer Service.
Old 04-16-2011, 12:21 AM
Re: Overheat
Yes radiator level is good, and yes I can feel the fans kick in...Maybe a clog somewhere???
Old 04-16-2011, 12:30 AM
Re: Overheat
Why do you need the VIN#? Seems everyone of ur posts requires one.
Seems to me all u would need is year and engine and symptom
Old 04-16-2011, 12:38 PM
Re: Overheat
are you able to check the radiator level...or just the over flow tank?
Live For Today
Yesterday is gone,
Old 04-16-2011, 01:12 PM
Schurkey Schurkey is offline
Re: Overheat
Because she's running a VIN-based check of recalls and service bulletins.
I heard GM was going to monitor web sites for "problems" with GM vehicles. We'll see how long that lasts. I'm going to have to check pistonslap.com to see whether anything useful has happened there...
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-16-2011, 02:15 PM
Re: Overheat
I just noticing oil in my anti-freeze, I have a leak somwhere
Old 04-16-2011, 02:51 PM
Re: Overheat
where are you seeing the oil??in the radiator?
oil in radiator will normally be trans oil,from a bad oil cooler
antifreeze in engine oil normally head gasket
have'nt heard of intake failure for this on the 3.1l engine
like we are seeing on 3.8 & 4.3
how many miles on the engine?
is this the 1st time you had over heating troubles?
Live For Today
Yesterday is gone,
Old 04-16-2011, 06:42 PM
Re: Overheat
I'm seeing oil or dark stuff in the radiator.
I'm at work and will have to get back to you on the milage.
No over heating problems till 2 days ago.
Old 04-16-2011, 10:17 PM
Re: Overheat
According to the odometer it says 200924 miles
Old 04-16-2011, 11:47 PM
Re: Overheat
keep an eye on both engine/trans oils see if there low but..
sounds like a bad radiator cooler(need a new radiator)
let us know,Good luck
Live For Today
Yesterday is gone,
Old 04-16-2011, 11:52 PM
ibbobud ibbobud is offline
Re: Overheat
Not good, either a bad lower intake gasket or blowed head gasket.
Usually oil in the radiator and overheating would indicate head gasket depending where the gasket is leaking. Not sure if LIM will get oil in the radiator or not.
90 Lumina euro 3.1 - New fuel pump/filter, new ecm, new egr valve, new upper/lower intake gaskets, new alternator, new O2 sensor, and it keeps going....
Old 04-17-2011, 12:17 AM
Re: Overheat
Or a cracked casting.
Head cracks are common on the 3.1/3.4. Hell, head cracks are getting to be more common on pretty much EVERYTHING. The wall thicknesses are reduced for weight savings; and the strength/durability goes away with every ounce saved.
Old 04-17-2011, 02:29 PM
Question Re: Overheat
Checked the oil and trans fluid and both levels are good. And no discoloration. However when I take the radiator cap off I have what looks like sludge. I guess intake or best case senario clogged radiator???
98 Sport Auto Transmission Overheats gromittoo 1st Gen 95-99 1 08-06-2010 06:16 AM
01 Blazer Overheats & Becomes Noisy Smilie1914 Blazer 2 07-11-2010 09:29 AM
Engine Overheats girishraj Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 11-07-2006 12:47 AM
Help, My car overheats... Kunundrum '88 - '91 Civic | CRX | Wagon | Shuttlee 12 11-10-2002 05:16 PM
my 1989 525i overheats harleybrokemyteeth 5 Series 1 10-24-2002 06:24 PM
