Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-15-2011, 08:31 AM
rogerscm85 rogerscm85 is offline
My Saturn SL2 Won't Turn On After Changing the Battery
Hi Everyone,
I was hoping someone would be able to help me out because I don't know much about cars. The battery in my 1997 Saturn SL2 wouldn't hold a charge, so instead of jumping my car each time I needed to use it, I bought a battery and had my fiance install it. After the new battery was put into the car it started right up, but the next morning when I went to go to work it wouldn't start. It makes a noise like it wants to start it just won't actually do it. I didn't know if anyone knew a solution to this problem. I hope someone can help because walking everywhere is getting annoying.
Thanks!
Old 04-15-2011, 11:30 AM
Collins Car Care Collins Car Care is offline
Re: My Saturn SL2 Won't Turn On After Changing the Battery
Sounds like you have a parasitic draw..
Old 04-15-2011, 02:11 PM
drew300 drew300 is offline
Does an SL2 have a trunk light? I've seen that on/off switch go bad on other cars. And check for an odd courtesy lamp that may be stuck on. Other than that, You'll have to find some-one who can use a voltmeter.
Old 04-15-2011, 06:23 PM
It makes a noise like it wants to turn on though. The lights still also turn on. Would it have anything to do with the battery if it still does these things???
Old 04-18-2011, 07:06 AM
1)So your hi beams are still good and bright? 2) even when trying to crank?
If they're bright when trying to crank, you could have bad (corroded usually) connections either at the battery or the starter motor. Or a bad starter motor. Also check for a good engine to chassis ground. (mine is at the upper motor mount, passenger side to the strut tower area).
Saturn SL2 won't start-not the starter michellej0000 SC/SL/SW 63 02-01-2014 09:18 AM
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
1998 Nissan Pathfinder Won't Start after replacing the battery aepcars Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-30-2008 04:38 PM
1998 saturn SL2 won't start unless the gas pedal is held in sixwongs SC/SL/SW 2 01-24-2008 02:58 PM
Random revs after changing the battery nicwymer Passat 3 01-22-2004 12:02 PM
Tags
1997 , battery , saturn , sl2
