Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-14-2011, 02:10 PM
cuda1979 cuda1979 is offline
99 rodeo with light knock after warm up
Hi I have a 99 rodeo with a light knock after warm up it sounds like it is coming from the bottom end it is loundest when you are under the engine or standing on the side by the front wheels when you give it gas you don't hear it that much. I have checked the timing belt tenioner and it does not seem to be making the noise. I have removed the engine and checked the rod bearings just looked at have not check the clearace yet. I did feel some side to side movement where rods connect to the crank do not know how much is ok. I am thinking about replacing the rod and main bearing but do not want to have to pull the engine again. Any thoughts on what I should do thanks
Old 04-14-2011, 08:58 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 99 rodeo with light knock after warm up
did you check the S-belt tensor?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-15-2011, 10:56 AM
Hi yes I did check the serp belt tenioner but it did not seem to be making any noise. any other thoughts?
update I have found the problem the cylinders are worn and out of round I had to have it bored out 20 over and buy new pistons and the noise is gone hope this helps some one
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 06:37 PM
Problem with car starting after its warm up deb789 Grand AM 0 12-10-2005 04:44 AM
Knocking/Missing after warming up 94/Z28 Camaro Discussions 3 03-23-2005 06:50 PM
Problem with 1990 stalling after engine is warm. gdroot Grand Prix 0 01-08-2005 08:18 AM
After warm horribly rough with misfire spinmaester Rodeo | Passport | MU 1 05-23-2004 10:31 AM
