Old 04-14-2011, 12:34 PM
pete44 pete44 is offline
92 chevy 1500 TPS circuit
Hello again..
Narrowed my rough idle problem to my TPS circuit..I shorted A and B together on DLC to check codes off ECM..Only showing code 22 (TPS Circuit Signal Voltage Low)..Which in fact ...It Is!
I first checked TPS connector for 5 volts with ignition key ON...GOOD
Then checked TPS connector between Blue wire and engine GND plugged into TPS..Read .05 volts..NOT .6 volts ..When I change my voltmeter scale back to proper scale it reads infinity (000)..When I go to wide open throttle it reads 4.0 Volts..
I am now looking at circuit itself.. The TPS wiring runs through firewall eventually to ECM.
What gets me about all of this is even the Chevy Dealer cannot look at this (OBD1) ECM system anymore!!! TOO OLD I GUESS
And by the way I have changed out the TPS already...
I'll trace/continuity check the TPS circuit to ECM..This still may be the ECM..Which I saw on a website I could get between 100 to 150 dollars.
Any suggestions appreciated!
Pete
Old 04-18-2011, 05:21 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 92 chevy 1500 TPS circuit
Originally Posted by pete44 View Post
Hello again..
Pete
Check the voltage readings to and from tps and then to PCM.
MT
1989 c/k 1500 1989ChEvY1500 C/K 3 04-18-2009 02:30 PM
TPS circuit low input lank_dogg_420 Blazer 0 12-05-2005 09:35 PM
dual exhaust on 1997 chevy 1500 abaird C/K 1 03-13-2004 01:34 AM
95 chevy 1500 lifted 4 inches fred71 C/K 0 12-31-2003 12:45 AM
88 Chevy 1500 Heater Core texasprd C/K 0 12-23-2003 11:54 PM
