caprice having some issues
Hello all...my 85 caprice is having some issues right now...when i start the car in the morning it back fires while it warms up...not enough to kill the idle ....but does it on like every other stroke...Im wondering if this is an ignition issue or carberator thing...also another issue im having is when crusing around town with the car fully warmed up and the the car ideling at its lowest rpm theres a tinging noise...sounds almost like the car will die or like maybe the car is struggeling for fuel...but it does feel like its gonna die...honestly sounds like a bolt just pinging around but i know its not something stupid like that...any ideas boys?
Re: caprice having some issues
By backfiring when it warms up, do you mean while it's in 'curb idle' (fast idle) or when it's under power?
That actually points to a possible failing cam lobe or two.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
| The Following User Says Thank You to silicon212 For This Useful Post: | ||
beat88ls (05-02-2011)
if this checks out good then check the plugs, plug wires for proper resistance.. the fuel filters on these vehicles mounted in the carb should be replaced every year ...this is because of your steel tank and alcohol fuel causes great amounts of rust to plug it up...one way to reduce this is add 2 oz of the marvel mystery oil to gas , when filling her up... |
man thats sweet you guys get back to me so quick!
Anyway yea so the back firing is only on a cold start...once the cars warmed up it doesnt do it...and once its warmed up and drops down rpm...from the cold idle to fully warmed and ready for cruising it stops....the clinking noise happens pretty much all the time...i would like to post a video on here but dont know how...should i pload to photobucket or something...that would make it easier for you guys to help me...Im gonna check spark plugs but they are all new and so are wires...to me it sounds like fuel filter..even tho its not that old...or maybethe choke...but i did take off the carb and fully rebuild and clean it within the year so i dont know...lemme know what i can do ... |
i have aftermarket headers and exausht
so the exhaust valve is gone....
headers will damage the plug wires...is this all properly insulated to protect the plug wires ? heat will damage the wires causing the resistance to increase over time ... |
Im not sure what the exausht valve is...but the plug wires are fine...
im gonna get a video up today... |
