Old 04-13-2011, 04:36 PM
jakeyf08 jakeyf08 is offline
99 Taurus rough idle after starting
After the car is started the RPMs jump up and down and there is some vibrating going on. Only occurs when vehicle is started. After you drive it, it's fine. Possible areas to start looking? Throttle? Fuel Pressure?
Thank you in advance
Old 04-13-2011, 08:33 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: 99 Taurus rough idle after starting
Sounds like a vacuum leak causing a lean condition and misfire. I'd start by checking the vacuum hoses, PCV elbow if you have the DOHC engine, and intake manifold.
-Rod
Old 04-22-2011, 08:26 PM
spflick spflick is offline
Rods Right Also try cleaning you mass air flow... throttle body, idle air control motor..... those may help and is good to keep them clean...
Rough idle during cold weather start mobzs Sierra 1 03-26-2011 12:00 AM
Idle Problem shortly after starting - Need help ASAP jp72 LeSabre 1 02-16-2011 03:38 PM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
Rough idles after starting car at high temps Iroc_Z28 Lumina 1 11-23-2005 02:20 PM
