Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '06+ Civic
Old 04-12-2011, 03:32 PM
JFol5 JFol5 is offline
Cylinder 3 misfire
2007 honda civic EX 4 cyl 1.8
Check engine and poor acceleration/higher than normal rpms happened at same time, struggled up a hill. Did the test and got cylinder 3 misfire.
Changed all 4 spark plugs to be on the safe side, checked after and no more code, but a couple miles later, car's in bad shape again and check engine back on. Checked again and it's the same code--cylinder 3 misfire...
Do you think I'll need a new ignition coil, new spark plug wires, or both?
Thanks a lot for any help on this.
Old 04-13-2011, 03:18 PM
Copytech99 Copytech99 is offline
Re: Cylinder 3 misfire
Swap the coil pack with one from another cylinder and see if the code follows the coil or stays with #3.
The Following User Says Thank You to Copytech99 For This Useful Post:
JFol5 (04-14-2011)
Old 04-13-2011, 10:05 PM
BullShifter's Avatar
98 Dakota single cylinder misfire following overheating 98dak0ta Dakota 2 01-28-2011 03:02 PM
Multiple cylinder misfire codes Pokee Windstar 6 05-04-2010 10:10 PM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 09:49 AM
P0305 Cylinder 5 Misfire wmuwop Explorer | Explorer Sport Trac 3 03-31-2009 07:40 AM
Weird #3 cylinder misfire gesellman Trooper | SLX | Bighorn | Wizard 2 03-07-2009 12:31 AM
