Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 11-07-2001, 10:34 PM
Blue93G20 Blue93G20 is offline
Angry Wtf
I can't figure out my problem with the radiator fans coming on. Any more suggestions cause right now my car is just sitting and you know thats got to be disappointing after doing a swap....HELP
P.S. this is BULLSHIT
93.5 Infiniti G20
JDM SR20DE
Lowered on Intrax, Hotshot Header and Hotshot CAI
15.90@88MPH
http://community.webshots.com/album/34345621pASGoo
Old 11-08-2001, 07:37 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Re: Wtf
But isn't that a good thing? Or do you mean your radiator fans don't come on?
Old 11-08-2001, 11:54 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Re: Wtf
That's what he means.
Old 11-08-2001, 06:15 PM
JD@af's Avatar
JD@af JD@af is offline
Missing in action
Send a message via ICQ to JD@af Send a message via AIM to JD@af
Fan clutch(es?) installed correctly? That could be the problem, but that's kind of a shot in the dark.....
Old 11-08-2001, 07:41 PM
SkylinesKillAll's Avatar
SkylinesKillAll SkylinesKillAll is offline
Send a message via AIM to SkylinesKillAll Send a message via Yahoo to SkylinesKillAll
hey jd u live anywhere near central? thats where im at now
Back in my day we didn't have all this fancy birth control shit; like pulling out.
:flamer: :monkeypis :bathroom::rocket: :badass:
Old 11-09-2001, 06:32 AM
JD@af's Avatar
Missing in action
Arrow SkylinesKillAll
You mean CCSU? I'm not far from there at all. Although on Mapquest, Monroe is about an hour from me.. which isn't all that far.
Old 11-09-2001, 04:40 PM
T4 Primera T4 Primera is offline
Re: Wtf
Since no-one has replied yet, I'll give you the lowdown on the engine temperature sensor according to Haynes manual for UK Primeras:
Engine Temperature Sensor
The engine temperature sensor provides information to the engine management electronic control unit to control the fuel and ignition systems, and the radiator cooling fan.
On all models, the sensor is located in the inlet manifold, at the rear (timing chain end) of the cylinder head.
The sensor contains a thermistor - an electronic component whose electrical resistance decreases at a predetermined rate as it's temperature rises.
The fuel injection/engine management ECU supplies the sensor with a set voltage and then, by measuring the current flowing in the sensor circuit, it determines the engine temperature. This information is then used, in conjunction with other inputs, to control the fuel injection/engine management system, and the engine cooling fan.
If the sensor circuit should fail to provide adequate information, the ECU back-up facility will override the sensor signal. In this event, the ECU assumes a predetermined setting which will allow the fuel injection/engine management system to run, albeit at reduced efficiency. When this occurs, the engine warning light on the instrument panel will come on, and the advice of a Nissan dealer should be sought. The sensor itself can be tested by removing it, and checking the resistances at different temperatures using an ohmmeter (heat the sensor in a container of water, and monitor the temperature with a thermometer). The resistance values are given below.
DO NOT attempt to test the circuit with the sensor fitted to the engine, and the wiring connector fitted, as there is a high risk of damaging the ECU.
Engine Temperature Sensor Resistance Values:
20 deg C ... 2.10 to 2.90 kilohms
50 deg C ... 0.68 to 1.00 kilohms
80 deg C ... 0.30 to 0.33 kilohms
Electric cooling fan cut-in temerature ... 82 to 88 deg C
Good luck!
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 11-09-2001, 05:53 PM
JD
yea im at CCSU sure gets boring here on the weekend. ill prolly have 100 posts by the end of tonight
wtf. just... wtf vinnym86 Stress Release 5 05-22-2006 07:10 PM
WTF is a Lancia VTEC V6 General Discussion 76 02-18-2005 09:40 AM
Wtf? enzo@af COMPLETELY off-topic 10 12-15-2001 01:06 AM
Can Anybody Tell Me WTF Is This??? R33 General Discussion 23 08-08-2001 11:57 AM
Fog lights pre-wiring: WTF? ales Maintenance 6 07-10-2001 02:56 PM
