Old 04-11-2011, 04:13 PM
houndog3 houndog3 is offline
A/c inop
I got a 97,5.7l z71. I went to turn the air on and i get nothing.And heres what i did.The compressor clutch does NOT engage.The ac light is on,fan works correct.I found the 10amp fuse under the hood and it checked fine and all the other fuses were fine there.I checked all the fuses in the cab aswell and they were fine.I unplugged the compressor and hot wired 12v to the compressor and the clutch did engage.then i started the it up with the compressor hot wired and she cranked out cold air.
does this system have a low refigerant bypass system?? if so where is it located at so i try to bypass it.thanks for any input
Old 04-11-2011, 07:13 PM
brcidd's Avatar
brcidd brcidd is offline
Re: A/c inop
Yes the cycling switch on the accumulator is the low pressure disable switch...but I would hesitate to tell you to replace it without measuring the refrigerant pressure-- the switch may be doing its job! It takes 47 psi pressure to enable the switch, if your system pressure is less, then you have experienced a massive loss of refrigerant. You need a gage set to measure pressure.
65% of mobile a/c failures are due to refrigerant leaks- so yours maybe low, and still had enough in it to make you feel it is cooling.
Number one leak location on your truck is the underbelly of the compressor-- is it oily/greasy? If so, that's probably the leak location.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
heater fan inop mickanic Laguna/Laguna II 2 10-29-2005 01:46 PM
cooling fans inop. and a/c inop. rylee40454 Caravan | Voyager 5 09-15-2004 02:20 AM
Rad cooling fans inop bubba6ca Caravan | Voyager 3 04-09-2004 05:21 AM
odometer inop ems Regal 1 10-19-2003 12:55 AM
95 accord EX Power steering inop. noob Engineering/ Technical 4 07-05-2003 09:22 PM
