Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 04-10-2011, 03:35 PM
snoozin snoozin is offline
Arrow Top plastic rad pipe cracked, can It be fixed?
The top part of the rad that the rad hose clamps onto has cracked. Its all plastic. Epoxy has provided a temp fix (3 days) till I change the radiator.
Is there any solution to fixing this cracked plastic, like heating it up or fusing it back together somehow?
I don't really want to change the rad.
1996 trans sport
Is there a pressure spike in the coolant system on engine start up? Thats when the epoxy likes to let go after its been running awhile.
Old 04-10-2011, 04:23 PM
inafogg inafogg is offline
Re: Top plastic rad pipe cracked, can It be fixed?
CRC makes an epoxy putty part #14071 i'v had good sucess with
might want to try before you replace radiator.
after its cured/dry you can sand,drilled.tapped.machined
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-10-2011, 04:44 PM
Scrapper Scrapper is offline
AF Premium User
1996 trans sport
can i ask you how it cracked? and i agree with infog.
Old 04-10-2011, 04:48 PM
I'm not sure, the van was given to me like this.
The crack is not on any part of cylinder part that the hose clamps to. Its next to it, or along side it.
I'm guessing since that rad hose is new, that the last person over tightened the clamp which cracked the plastic tube that its clamped to.
The mounting doesn't seem good, the rad is wobbly on that side.
I was thinking of heating up the cracked plastic with a small torch and just weaving the cracked plastic together. Good Idea? Or should I try another epoxy. I put on a whole tube of heat resistant permatex epoxy and it just wont hold long enough..
Old 04-11-2011, 10:38 AM
AF Premium User
yes you could try that on welding plastic but before i'd go on long trip i would be looking for a rad. when they started out on plasic people would pressure test them and then they crack.
Old 04-11-2011, 06:44 PM
Will a rad from a 1997 Trans Sport fit in a 1996 Trans sport?
The guy selling the rad said: fits transport or a lumina van between a 1990 and 1995.
But i'm just wondering since it looks new and its cheap.
Old 04-11-2011, 07:36 PM
LMP's Avatar
LMP LMP is offline
There are various configuration for the transmisison and engine oil cooler loops in the side tanks. Verify athat when you look for a replacement
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-12-2011, 09:56 AM
AF Premium User
go on autozone.com see if same part number for that rad.
FIX a cracked and bent aftermarket chrome wheel...HELP! georgetracy33 Tires and Wheels 0 08-05-2010 10:29 AM
98 Cav Rad Inlet Pipe MrCheapGuy Cavalier Problem Diagnosis 2 04-20-2010 07:50 PM
Metal vs Plastic CAI pipes MaNtiS3024 Mustang Talk 2 10-28-2003 09:41 PM
