Old 04-10-2011, 01:58 PM
ND4SP's Avatar
ND4SP ND4SP is offline
Question Engine cooling fans not working at all
I have a 2005 Buick Lesabre Custom. Neither of the cooling fans work at all. I checked to see if the relays were all fully seated and reseated them to make sure. Fans are not frozen. Is there a way to jumper out the relay to see if the fans are ok???
2005 Buick Le Sabre: Cooper CS4s, Fram Air Hog and Silverstar Ultras Low beams and highbeams. LED tails and marker lights , brake/turn signals (front turns too) coming soon, just need to install resistors in circuit.
(Sold ) 1999 Intrigue: Fram Air Hog, Bridgestone Potenza G009(Love em, just a little road noise)Upgraded to G019 grids they were even better. Silverstar Low beams and highbeams. Led brake lights, all marker lights and third brake light.
Old 04-10-2011, 09:28 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Engine cooling fans not working at all
If you turn the A/C on, does the fan come on?
Old 04-11-2011, 11:17 PM
ND4SP's Avatar
Unhappy Re: Engine cooling fans not working at all
No they don't, I forgot to include that in my message. I checked to see if there is power at the relay, and found that it is live all the time( on the input of the relay ). Even tried swapping one relay for another ( can't swap one, it is a sinlgle pole, double throw, may have to bench test that ).
Old 04-17-2011, 03:56 PM
ND4SP's Avatar
Talking Re: Engine cooling fans not working at all
Fans now working with AC on , reseated relays and now they work. Car was in an accident and just came back from the body shop. I will keep an eye on them to make sure the keep working.
Engine Cooling Fans Not Working alydar66 Caravan | Voyager 23 07-15-2013 02:53 AM
AC Clutch Not Engaging and Cooling Fans Not Working (I think) 1999montana Montana/Montana SV6 3 03-06-2008 09:16 AM
cooling fan not working jmack17m Jetta/Vento/Bora 4 07-24-2004 09:06 PM
Cooling fans not working springbreakdave Grand Prix 2 12-10-2003 07:38 PM
