Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-10-2011, 12:00 PM
010175 010175 is offline
replace just the fuel pump in assembly?
How easy is it to replace just the fuel pump in the fuel pump assembly? I can buy just the pump $92. or the whole assembly for $204. I have replaced the assembly 2 time in ten years but now the auto parts store has both the assembly and just the pump. Any ideas of the time it takes to replace just the pump in the assembly? Thanks Dave
Old 04-10-2011, 02:43 PM
brcidd's Avatar
brcidd brcidd is offline
Re: replace just the fuel pump in assembly?
I've never done it-- I value my time too much..and don't like dropping the same tank twice in a year.
That $204 price is great if you are going to sell your truck, or intend on wrecking it. I can only assume it is an Airtex or some other afternarket unit. If you intend to keep it, I'd only use OEM pump assembly- the Delphi or A/C Delco units.
The advantage to the new pump assembly is you don't have fuel sender unit issues, which are so common on the OEM units. When you replace the pump, you also replace the sending unit- a definite plus- it is no fun to replace a pump, then 6 months later have fuel guage issues.
Bit the bullet and put in OEM equipment pumps, the sender units have been improved on the replacements, as well as the electrical connectors.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
010175 (04-10-2011)
Old 04-10-2011, 02:52 PM
Thanks, I have not idea how long this 250,000 mile car will run. I dont mind rolling the dice. I was just wondering how much trouble is was to change out the pump in assy. Dave
Old 04-10-2011, 03:11 PM
inafogg inafogg is offline
its not that much more time or harder.maybe 1/2 hour.if you can get the pump
in the delco/delphi,i'd just replace the pump
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-14-2011, 05:43 PM
paulson paulson is offline
AF Pro
Just buy an el cheapo off of eBay... it'll be around $80 and it'll last at least 50K
Old 04-14-2011, 05:56 PM
spend the extra $20.
Live For Today
Yesterday is gone,
Old 04-14-2011, 07:09 PM
j cAT j cAT is offline
with that many miles an if you do not plan on keeping this much longer I would get a cheapo pump..just stay away from airtex..
keep the fuel tank above 1/4 at all times to avoid burnout.
with gas going above 5.oo / gallon you will be looking for another higher MPG vehicle to do most driving ..
I use the truck for truck work and the car for small stuff..
The Following User Says Thank You to j cAT For This Useful Post:
010175 (05-07-2011)
Old 05-07-2011, 12:06 PM
Thanks to all!! I got a pump and sock only (Sunday night, only store open). I dropped the tank, pulled the pump assy and replace the pump. I had to bend down the bottom tin ring, pulled out the pump and pushed the new one in and bend up the bottom pump support tin ring back. Then put on the new sock. Thats the only way i could see to do it. There was no bolts to take apart the assy to remove just the pump. Worked fine. Thanks Dave
Old 05-07-2011, 01:37 PM
cris2004 cris2004 is offline
First time I did a fuel pump in my Suburban I pulled back the carpet and cut an access panel. I've cut the bed in my pick up trucks as well. The odd time there is an issue, or the next time a repair is needed it is sweet indeed. Helps if you can weld up the cut out piece with a lip for easy re-installment.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
bmw 325 fuel-pump testing and replacing dieter 3 Series 2 08-12-2009 02:46 PM
info needed on replacing fuel pump bri45 Cutlass Series 1 07-12-2009 08:29 PM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
