Old 04-10-2011, 09:33 AM
y2kblazer y2kblazer is offline
1351 code
2000 blazer 4.3, 4wd.. Throwin 1352 code. No start. Cap, rotor both delco& 2mos old. Swapped coil, ck c4 pin #18 to coil plug good, other wire to ign mod good continuity also. (no cont from c3 #9 to c4 #18 tho.. Saw on another post)Can bad or failing ign mod throw 1351? Or any other ideas? Thanks
Old 04-10-2011, 05:09 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1351 code
Yes it could.
Also anti theft codes can to.
Any other codes?
Best to get the repair flow chart for that code and go threw it.
MT
Old 05-16-2011, 04:40 PM
Re: 1351 code
ended up being a bad ignition module... free. had replaced it about 2 1/2 years prior. lifetime warranty at o'reilly
The Following User Says Thank You to y2kblazer For This Useful Post:
blazee (05-16-2011)
Old 05-16-2011, 04:44 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 1351 code
Thanks for the update.
code 24 zetan Corolla/Matrix/Voltz 2 04-10-2009 09:59 AM
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
01 Sport Trac Door Code??? levi.calhoun Explorer | Explorer Sport Trac 1 03-23-2009 10:09 PM
1351 code prntsails55 Blazer 4 02-01-2005 03:34 PM
