Old 04-09-2011, 02:31 PM
wolvyreen's Avatar
wolvyreen wolvyreen is offline
Honda S2000 - My First Build
Hello AF model builders.
It's good to be back
I have been AFK from model building for almost 6years now. I have never finished 1 model but I am back and wanting to do this again because I had personal reasons the last time for not continuing with this wonderful pastime.
This is the original thread that I started way back when and i have decided to rather start a whole new thread because I have chosen to strip the paint ONCE again to put a proper solid color on the body.
Back then, I had a lot of trouble with the body and it broke in 2 places. After this latest stripping, it broke completely. As you will see below. BUUUTT!! I honestly believe it is fixable and I will give it my best shot! The breaks are clean and some reinforcement will do the trick I think.
If I can't fix it, I will just go out and buy a new kit and use it as spare parts.
Anyways...GASPS are now welcome
Old 04-09-2011, 02:36 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Re: Honda S2000 - My First Build
Wow...
The body is probably fixable but if it broke up like that it means the plastic has become too brittle due to the multiple times you've stripped the paint (I assume you used brake fluid?) so there's no guarantee you won't run into further issues as you go along. You have to ask yourself if you want to go through all the trouble of putting a broken body together for your first build. If I were you I would get a new kit and leave this one for later when you're more comfortable with the hobby you're getting back to.
Good luck in any case!
Old 04-09-2011, 02:50 PM
wolvyreen's Avatar
meh, i'm not too phased. as I said, I will just go buy a new kit and replace the body and all the other extras, I will use as spare parts
Old 04-10-2011, 02:26 AM
wolvyreen's Avatar
Ok, Small update
Last night I glued the pieces back together. I still got some work to do to clean things up a little but overall I am happy with the result. I am now even more hopeful that I can still make this body work.
Persevere!!
BEFORE
AFTER
TOP VIEW
Old 04-10-2011, 02:55 AM
ales's Avatar
Forza Schumacher
Make sure you cement some plastic strips on the inside of the joints to reinforce them.
Old 04-10-2011, 03:19 AM
wolvyreen's Avatar
Thanks for the tip I am planning on doing that, I just need to go to the LHS to get some.
Old 04-10-2011, 07:14 AM
wolvyreen's Avatar
Ok, the body has been sanded and ready for some good old soaking in soapy water for about an hour before she gets a good scrub down and goes off for drying.
In she goes before a good drying and priming to reveal all those bad and ugly spots.
Of course I must not forget the underside for cleaning too :P
Old 04-10-2011, 09:48 PM
lilcraigford lilcraigford is offline
Wow, that is an ambitious fix!
Old 04-11-2011, 02:04 AM
kaho's Avatar
kaho kaho is offline
Way to go fixing that body! I think it is enough of a feat that I would personally even build up the model looking just like that, without painting the body. As already mentioned just make sure you reinforce the body enough to last through polishing your next paint job and the last step of putting the body onto the chassis.
Old 04-11-2011, 03:34 AM
wolvyreen's Avatar
Yes I am off to the LHS today to get some plastic strips for reinforcement
Old 04-12-2011, 03:28 AM
wolvyreen's Avatar
ok, so none of my LHS have plastic for me. I would just like to ask, is this what I should be ordering? Cause I am not sure what to buy.
http://www.tamiyausa.com/product/ite...oduct-id=70003
Old 04-12-2011, 04:41 AM
rallymaster's Avatar
yes it is, nice price moreover !
you're on the way to an ambitious restoration project, such wrecked body would have discouraged many of us and simply be replaced by a new one, that only worses to follow your progress whatever the final model would be !
Phil
Old 04-12-2011, 05:41 AM
wolvyreen's Avatar
Thanks Phil I am going to do whatever I can to make this work! this is my first build and I'm not giving up easily.
About the styrene, aren't there styrene strips from Tamiya?
Old 04-12-2011, 07:44 AM
there might, but the most common and seen styren strips, rods, tubes etc are made by Evergreen even if some stores don't inevitably release the Evergreen range (it's the case here in France, only a few specialized stores have the full range regularly updated and restocked).
Phil
Old 04-12-2011, 09:14 AM
ales's Avatar
Forza Schumacher
Another good source for styrene goodies is http://www.plastruct.com/
Nyce1s Crash Video - ADTurbo 8 Second Honda S2000 Crash @ NSCRA PBIR Finals 2010... nyce1 Car Videos 0 01-19-2011 01:45 PM
What can i do with my S2000? I want to make it a 10-11 sec. car ladeedodd S2000 11 02-01-2010 08:01 AM
Honda S2000 First pics Wishmaster WIP - Street 3 04-18-2002 04:27 AM
