Old 04-09-2011, 06:14 AM
fireplow fireplow is offline
2002 4.2 hard starting
i've got a 4.2 in a e150 it's hard to start at least 3 trimes cranking it befor it starts. it will back fire through intake almost but after it gets started it run fine. now when it's around 48mph or 54mph the motor will buck like it's shuting off. I have replaced the crank shaft acd cam shaft senors could it be the coil pack your the pcm/ecm
any help wound be great tks
Leonard
Old 11-14-2012, 09:05 PM
fordtech2192 fordtech2192 is offline
Re: 2002 4.2 hard starting
Leonard
Hi Leonard
I just seen your post now and I'm understanding that your e-150 may be having a hard start problem because your not getting enough fuel. I would check you fuel pressure by hooking up a fuel pressure gauge and finding the spec you need for your vehicle. by my understanding it could be your fuel filter.
1994 Ford Explorer Hard starting after it sits. privottfamily Explorer | Explorer Sport Trac 3 05-01-2012 05:14 PM
2002 4.2 hard to start luxeryvic F Series 6 01-28-2011 04:26 PM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 04:21 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
