Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 04-08-2011, 07:57 PM
russ3654 russ3654 is offline
Wheel bearing maybe trans?
I have a 01 Accent, 5 speed,there is a grinding noise from the front driver wheel, and it seemed to be running hot. Took the caliper off, seems fine. Removed the axle nut, to inspect as much as we could. Jacked up both front tires, the passenger in nuetral spins easily by hand, the drivers doesn't, but the tire moves back and forth with a little play, caliper is free, and bearing. Ran the car jacked up and just the passenger tire spins, the driver side does not. Any suggestions is the trans bad or is this normal???
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 11:27 AM
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 08:23 PM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 09:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 09:37 AM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 11:22 PM
