Go Back   Automotive Forums Car Chat > Cars in General
Old 04-08-2011, 05:09 PM
bad tire purchase bad tire purchase is offline
Grooved roads and cheap tires
Howdy,
I put a set of Falken Ziex ZE 912 tires on a Honda Accord and they are terrible on grooved highways ... Anybody know if the annoying side-to-side motion can cause damage or excessive wear and tear to the car in any way? (or should I find another reason to blow another $500 on less annoying tires?)
Thanks!
Old 04-08-2011, 05:20 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: Grooved roads and cheap tires
Hmmm, Falken has a pretty solid reputation, but I always found they wore unevenly on my Infiniti G20.
So you're saying the car almost floats on grooved roads?
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 04-08-2011, 05:29 PM
Thanks for the reply, Speediva ...
Yep, floats is a good way to put it. Just a constant to and fro motion as the tread tracks the road grooves. The tires are fine on smooth roads, gravel and in the rain ... not great on ice, which I suspect is because the rubber is so hard (that's what I get for falling for the 65K warranty).
Old 04-09-2011, 12:03 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I think your problem lies elsewhere, and is not the tires.
I am a big believer in having an alignment done whenever I buy new tires. Periodic alignments and a thorough check for worn suspension components is important.
Imho your handling problem may well be due to a poor alignment (too much toe-out) and/or worn components, such as tie rods, bushings, ball joints etc.
Other possibilities...... I presume the tire size is the same as stock, inflated properly (NOT to the max rating written on the tires) and you have stock rims, right? Wider-than-stock tires can cause wandering.
FWIW I looked through about 40 reviews of these tires on-line. Nobody mentioned wandering as a complaint issue. But they did say these tires wear out pretty fast, 12,000 - 50,000 miles, so the 65K warranty you have is probably a good thing.
decent and cheap off road/racing tires? doberman_52 Tires and Wheels 1 09-08-2006 02:11 PM
F/S 22" and 23" tires, cheap. 73'Camaro Cars/Parts for Sale/Exchange 0 08-23-2004 04:04 PM
I need good used and cheap tires.... Hey its antman Tires and Wheels 6 05-15-2003 01:21 PM
