Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-08-2011, 03:16 PM
mishalah's Avatar
mishalah mishalah is offline
AWD vs. 2wd mileage?
Do any of you with the AWD setup ever turn it "off" and use the 2wd only? If so, does it improve your gas mileage?
Old 04-08-2011, 04:41 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: AWD vs. 2wd mileage?
What vechical?
Most AWD drives are AWD all time.
No turn off.
4W drives has 2W and 4W
MT
Old 04-08-2011, 06:20 PM
j cAT j cAT is offline
AWD uses more fuel ...2wd would give about 3 MPG more with the SAME TYPE VEHICLE ... as mentioned AWD is not designed to be any other configuation...
another negative about AWD , all tires must be matched and rotated.. If not this will lower the MPG and cause drivetrain wear..
Old 04-09-2011, 04:39 PM
mishalah's Avatar
This over-optioned soccermom version of what used to be a real truck is turning out to be more pita than what all these options provide. The completely controlled suspension and drivetrain of this luxo-barge is just too overcomplicated and subject to expensive breakdowns.
OTH, it is a very nice ride.
OH...speaking of "ride" I pulled the Autoride airshocks and put in a set of SensaTrac load adjusters with the 1200 lb springs. It feels better already. But....I don't know how it's gonna mess with all the computer controlled junk in the system.
Selectable 4WD/AWD and 2WD dezso3 Cars in General 0 03-11-2010 09:29 PM
Selectable 4WD/AWD and 2WD dezso3 Cars in General 0 03-11-2010 09:28 PM
Yukon-vs-Yukon Denali...AWD-vs-4WD..towing/offroad...decisions...decisions mad max Yukon 2 12-11-2009 02:06 PM
700r4 4WD vs 2WD tomkr101 General Discussion 0 06-03-2005 09:31 PM
Alaska roads vs. 2wd Ford van. cadjak Engineering/ Technical 4 05-13-2005 06:06 PM
