Dodge Dakota 2001 Misfire on Cylinder 1...
Recently I have been having misfire on cylinder 1 and a couple multiple misfires. I have replaced spark plug wires (replaced twice, thought possible bad wire from new), rotor, distribtor cap, spark plugs, coil pack. I had taken it to a garage to have the injectors cleaned with new seals, o-rings, mainfold gasket replaced because it was leaking, pcv valve cleaned, oxygen sensor replaced, fuel rail cleaned. This did help alittle. Now I do not get any multiple misfires, but now I get a consistent misfire on cylinder 1, when it misfires (on occasion). What does you think would be the next thing to do?
Re: Dodge Dakota 2001 Misfire on Cylinder 1...
checked engine compression, or you can swap injectors with another cylinder
So I did do compression tests on all cylinders... It seems that they are around 72 PSI. Is that normal? Doesn't seem like it is a head gasket. Just yesterday, before the compression test on cylinders... I had the truck have a multiple misfire with cylinders 1,3,5. So now I dont think it is an injector problem now... What else could it be?
Thanks in advance, marauder12 |
72 psi ????you sure that's low..
