| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
H22/F22 parts
this may make me sound stupid but if i were to buy an h22 long block would any parts be salvagable from my f22 in my accord like the alternator, distrib, slave cyl, starter, etc? iknow i would need to get a trans, harness, shift linkage among other parts. i just paid like 300 to boost my old alt and bought a bunch of other new parts and i really would hate to start all over again. i know the answer is probably no but i just need to make sure
as far as i know, none of the parts would be interchangeable.
but try to look up up some parts and see if they have the same part number, if the numbers are the same, then so is the part.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Re: H22/F22 parts
www.cb7tuner.com |
You can use ur f22 trans.
what about the shift linkage and axles id figured the axles wouldnt be strong enough to handle the power or does it not matter i really need to make a list of what i can and cant use any help? |
Yep f22 trans with the shift linkage and axles. My bro is gonna be doin h22 swap hopefully next month on his 92 accord. go here www.h22a.org |
like I said above yes you can use those parts. you actually need to use the accord axles. shift linkage theres absolutely no reason to change, but you could if you wanted to. trans I would go with h22 but its not necessary. it is manual im assuming? you will be ok then. also about h22a.org, last I checked which was only a few days ago it was still down.
www.cb7tuner.com |
thanks alot, seems that ill end up saving a whole lot of $ by going the longblock route and yes it is manual
I believe its just the forum section thats down. |
