Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-07-2011, 10:07 PM
boilerhorn boilerhorn is offline
2001: drive train noise while coasting, in gear
2001 Suburban, 140k miles.
I've noticed a strange noise while coasting with the vehicle in gear at lower speeds (under 30 mph). The best way to describe it is as "sh sh sh sh sh" at a tempo proportional to the speed of the vehicle. When I push the gas, the sound seems to go away (or it is masked by the engine sounds - I cannot tell). The sound persists when the brake is engaged, though.
I replaced the U joints about 30k miles ago and I checked/verified that the drive shaft had no play (the best that I could). I do notice a VERY slight clunk (clunk overstates it) when I press the accelerator. As already noted, the sound seems to go away when the accelerator is engaged.
I do not recall it happening in neutral, so I need to verify that.
Any help is appreciated.
Old 04-08-2011, 06:49 PM
j cAT j cAT is offline
Re: 2001: drive train noise while coasting, in gear
the clunk noise when accelerating ......this may be those U joints.
these can be bad again..replacing them sometimes gets them damaged.. then you have the chinese U joints which many have had bad results..
If it is the U joints it won't take much longer before you will know for sure.
tires can make the sh noise.. this is when the tire belt gets broken . check tires for irregular wear.
drive train comparison thedkid1 Car Comparisons 2 12-14-2010 05:25 PM
Clicking noise while coasting under 30mph bankroll Envoy 3 09-09-2008 03:24 PM
Drive Train noise jonwoolf ES300/ES330/Windom 1 10-03-2005 01:44 AM
Drive train noise CARPROBLEMS Camaro Discussions 2 07-21-2005 10:48 PM
Cold Temp drive train noise bioman63 Trooper | SLX | Bighorn | Wizard 0 04-19-2005 07:02 AM
