Old 04-06-2011, 08:33 PM
senrab senrab is offline
Long crank and low fuel pressure
92 GP LE with 130k 3.1L
It has a new fuel pump, relay and regulator. When you turn the key on for prime it barely registers on my pressure gauge. Turn the key on 2 or 3 times and it still doesn't have much. If you start cranking the pressure will jump right up to 45 psi and then it starts. The problem is you have to crank on it for 10 ~ 15 seconds before it builds up to pressure. Once its running it is fine and has no performance problems. It will not hold pressure in the fuel rail when you shut it off.
What have I overlooked or not checked?
Thanks for the help!
Just an ol fart, fartin around.
Old 04-06-2011, 10:05 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Long crank and low fuel pressure
Hi,
Have you inspected/replaced the fuel filter? I'm thinking maybe the filter is too clogged until the pressure builds up enough to brake trough the blockage inside...
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 04-07-2011, 09:10 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
cheap aftermarket fuel pumps are famous for bad pressure valves. There is a one-way valve built into the fuel pump that prevents fuel from back feeding through it to the tank. This is what your problem sounds like. You may want to test your vacuum supply to the pressure regulator as well, just to eliminate it as a possible cause.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-08-2011, 03:18 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Might want to pull the fuel pump wiring diagram.... Maybe Oscar can help. On these cars, if the fuel pump fuse blows, or the relay goes bad, there will be no voltage to the pump during key on. Then when the motor is cranked, the fuel pump can sometimes be supplied voltage when oil pressure builds. Thus starting. Someone with a 94 or older GP want to test this theory? Pull the fuel pump fues or relay, see what happens when you try to start. The car will not fire right away, but then once oil pressure builds, voltage is supplied to the pump through an alternative circuit and the car starts after a longer crank time. Hope this makes sense.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-08-2011, 10:40 PM
olopezm's Avatar
Here's the diagram, I guess this is a bad day for my electrical skills as I can't find a good way to understand the diagram, looks like today's work caused me a brain freeze LOL.
The Following User Says Thank You to olopezm For This Useful Post:
grog11 (04-16-2011)
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 02:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 06:32 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 09:09 AM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 06:12 PM
Ignition Switch and Low Fuel Pressure COClone Grand AM 1 07-18-2006 07:37 PM
