Go Back   Automotive Forums Car Chat > Hot Deals
Hot Deals A place to find and discuss the best deals online.
Old 04-06-2011, 04:47 PM
blazee's Avatar
blazee blazee is offline
Problem?
Rockford Fosgate Punch P1 P1S415 15-Inch 400 Watt Subwoofer - 4 Ohm $41.41 @ Amazon
http://www.amazon.com/dp/B001B6WVHC/
  • 15-inch, 4-ohm subwoofer with 400 watts maximum power handling (200 watts RMS)
  • Thermoformed polypropylene cone with high-density poly-foam surround
  • High-temp voice coil with spun-laced Nomex re-inforcement collar
  • Mount in either direction; reversible trim ring included
  • Designed for small enclosures
Amazon.com Product Description
If you're looking for big bass on a budget, look no further than the P1 15-inch subwoofers. They perform best in small sealed and vented enclosures unleashing the deep bass that made Rockford Fosgate famous.
Rockford Fosgate Punch Series Subs
Featuring innovative parabolic cone designs, oversized surrounds and large motor assemblies, Punch subwoofers deliver deep, loud, aggressive bass--not to mention stunning cosmetics that you'll want to show off. For over 20 years, Punch subwoofers have shown the world that big bass, extended power handling and awesome cosmetics need not cost a fortune. One listen and you'll know why it's called The PUNCH.
P1S415 Features
Speaker Construction
  • Custom 10-AWG nickel plated push terminals
  • High density poly-foam surround
  • High-temp voice coil with spun-laced Nomex reinforcement collar
  • Linear spider with embedded 16 AWG tinsel leads
  • Parabolic injection molded ABS/Acrylic dustcap
  • Protective PVC textured magnet cover
  • Reversible ABS trim ring
Aluminum V/C Former
Rockford Fosgate subwoofers use anodized aluminum voice coil formers that provide excellent heat dissipation. Unlike traditional plastic substitutions, aluminum acts like a heat-sink to quickly dissipate thermal build-up on the voice coil. This keeps subwoofers cool during high SPL conditions.
CEA-2031
Power handling on Rockford Fosgate speakers conform to CEA-2031 industry standards. This means your speaker has the capacity to handle power under continuous damand, not instantaneous power handling, that over time, can damage voice coils.
Reversible Mounting
Rockford Fosgate subwoofers can be mounted in either direction. A removable trim ring can be installed on the back or front side of the subwoofer frame. This gives the subwoofer a finished look regardless of mounting configuration.
Stitched Tinsel Leads
Multipoint "periodic" stitched lead wire technique reduces the mass of each tinsel lead and spreads stress and strain over a greater area, significantly improving the reliability and performance of the subwoofer.
These stitched tinsel leads withstand extreme duty cycles, fatigue and high current that is critical to robust design.
SUBS: Rockford Fosgate PUNCH vs. Audiobahn gillman6000 Car Audio 63 12-18-2004 01:11 PM
2 ROCKFORD FOSGATE PUNCH 12''s for Sale drumsrock99 S-10 1 11-30-2004 09:16 PM
2 ROCKFORD FOSGATE PUNCH 12''s for Sale drumsrock99 Group Buy Market 0 11-30-2004 06:09 PM
rockford fosgate 401s 1200 watts? pecos bill Car Audio 1 08-23-2004 10:28 PM
