Old 04-05-2011, 09:34 AM
dynastykid22 dynastykid22 is offline
1999 Chevy s-10 Please help
Truck cuts out when I give it gas, almost feels it is getting an extreme amount of air, bad hesitation, idols perfectly fine, starts fine. I have changed all spark plugs, wires, fuel filter, air filter, oil filter, and changed the oil. Fuel pump sounds fine, there is no distributor cap, only coil packs, also no check engine lights.
Any advice on the next step would be appreciated.
Thank you
JT
Old 04-05-2011, 09:54 AM
Scrapper Scrapper is offline
AF Premium User
Re: 1999 Chevy s-10 Please help
Thank you
JT
what moter you got in there 4cyl or v/6 and is it multiport fuel injection? could be tps or cps sensor also you could try cleaning maf sensor or gunked up throtle body take hose off throttle body and look in at the butterfly and see if it's dirty if it is they got spray to clean it.
Old 04-05-2011, 10:00 AM
It is a 4cyl 2.2, manual.
Old 04-05-2011, 10:03 AM
Will try em all and let you know.
Thank you
JT
Old 04-05-2011, 12:02 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thank you
JT
Before throwing parts at it do some proper testing.
Any check engine light?
Check fuel presure for up to specs.
Check for good hot blue spark to all plugs.
Let us know what you find there.
MT
1999 Chevy Prizm - Instrument Panel light bulbs ( LED replacement) n1ckml007 Prism 0 02-07-2011 01:08 PM
1999 Chevy Prizm - lock rod clip? n1ckml007 Prism 1 12-21-2010 09:41 AM
1999 Chevy Prizm - defogger switch light bulb ( LED replacement) n1ckml007 Prism 0 11-09-2010 09:26 PM
1999 Chevy S-10 Front Brakes Questions plopper73 S-10 2 12-15-2004 03:46 PM
