Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-04-2011, 11:57 PM
truc0011 truc0011 is offline
Keyless??
Do all Montanas have keyless? I just got a 2003 with no remotes. How can I tell which remote to get and if in fact the van has the module? If it doesn't have it can I add it?
Also with a 2000 Montana I had I could put the key in the door lock and hold it in one direction to unlock the doors and the opposite direction to lock them, the 2003 does do that. Can it be added?
Old 04-05-2011, 07:47 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Keyless??
Do you have an electric lock/unlock switch on your doors? If so, If all you want to do is lock/unlock, you can buy an aftermarket system for about $35 online that will work just fine and doe not care if you have a module or not. This would be much cheaper than buying OEM remotes.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-05-2011, 10:36 AM
Re: Keyless??
Remotes are pretty cheap, but I will keep this option in mind. Does anybody know if all Montana's have keyless? I know I can call the dealer with the vin but they never like giving me too much free information.
Old 04-05-2011, 12:17 PM
brcidd's Avatar
Re: Keyless??
Is "UA6" on your RPO code list? on label usually on back of glove box. If so, your vehicle had keyless entry OEM.
Or, you can remove your upper trim panel on top of dash, below windshield and see if you have a RCDLR (remote control door lock receiver) module.
If you have electric automatic door openers on sliding doors- you can bet you have keyless entry module and RPO code UA6.
'99 GMC Yukon
Old 04-06-2011, 10:36 AM
woscarr woscarr is offline
Re: Keyless??
So far as I know YES all Montana's, Venture's and Silhouette's 97 and above (new body style) came basic feature 'keyless entry' system.
I have a 98 Trans Sport (same body as Montana) keyless with no other power features.. ie; no power windows.
I also have a 02 Silhouette (same body also as the Montana) with keyless and full power options.
Check ebay to get those key fobs pretty cheap $20 range.
Cheers.
Wayne.
Old 04-07-2011, 12:49 PM
rkvons's Avatar
rkvons rkvons is offline
Re: Keyless??
You can look under the dash to see if that module is under there, but I think I would assume you have it. Then I would go to a place like http://www.remote-superstore.com and get the one for your vehicle, based on whether you have 1 or 2 power sliding doors. I would try programming it and see what happens.
Old 05-04-2011, 03:15 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Keyless??
Yes, all Montanas do from 97-forward.
The only difference will be what remote type you will use, depending on if the vehicle has power sliding doors, as there are a few options:
http://originalkeyless.com/searchqui...200+Montana%22
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Keyless Entry Info...Search here first before posting about keyless entry problems. rubberman General Discussion 570 08-10-2018 09:19 AM
3 Button TDS Transmitter Assy - Keyless hasabhi Camry/Camry Hybrid/Vista 1 03-26-2009 01:18 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 06:37 PM
I have keyless entry, but no keyless remote for my 96 Tahoe - need advice Adventurer_96 Tahoe 3 01-25-2008 01:07 AM
